Question about Dryers
Creda advance condenser dryer not heating - Dryers
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Posted on Jan 10, 2010
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | AEG T58840 Dryer Electric
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
How to replace of heating element of creda condenser dryer model t632cw? and where i can buy the heating elements?
Here are the major heating faults and we have loads more films in our video library on appliance repairvideo’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
You-Tube video "oYErKqR3LsY" placeholder (do not delete)
Dec 26, 2009 | Dryers
Creda Dryer not working - just rotates no drying
IN FIRST INSTANCE DONT JUST SWITCH OFF APPLIANCE - REMOVE PLUG FROM SOCKET AS WELL.
On rear of dryer their is a panel - under this panel lies the heater assembly and two protectors (TOC'S) it is more than likely that one of these has failed - Test with meter to find which one..
Apr 06, 2009 | Dryers
No heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Creda advanced t601cw leaking from back
this could be a pipe of or the condenser is blocked but this might be helpful as well thermostats or heater
Common faults -
Nov 06, 2008 | Dryers
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Dryers Logo
181 people viewed this question
Top Dryers Experts
