Question about Asko Washing Machines
Replacing the plastic control panel on my Asko 20005 washer
The plastic control panel on my Asko 20005 washer has broken in some places. How can the two circuit boards mounted to the orig. plastic control panel be installed onto a new control panel? They appear to be held in place and properly spaced one above the other by some clear plastic supports that come through holes in the circuit boards themselves and are mounted to the back (inside) of the control panel somehow.
gittos73
  • 244 Answers
SOURCE: Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Posted on Sep 12, 2007
duby1990
  • 370 Answers
SOURCE: I have a Frigidaire Gallery
It can be be your speed control unit. It also can be your door switch. Even though it locks there is still another switch inside that sometimes fails. That is your cheapest way to start and a lot of times that fixes it. If not replace the speed control unit.
Posted on Nov 18, 2008
SOURCE: Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Posted on May 12, 2009
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
MNTECH
  • 1543 Answers
SOURCE: Something rolling inside the Drum
The rear half of the outer tub, with bearing is part # 131525500 and it looks like the back "spider" shaft is not available as a separate part from the inner drum. The "spider" shaft is most likely worn or damaged and in need of replacement also.
131618500
Then, there's that strut
134564200
Now, two pain in the back side hours of your labor and you've got your washer back, at more than what a new one would cost! Junk it and get a new larger capacity front loader.
Please don't rate this, as anything but the top rating will lower my score. I'm just giving you my honest opinion, that your machine is not economical to repair. I've owned a LG front loader for over 6 years and think they are the best, but there are other good front loaders out there also.
Posted on May 19, 2009
I have an Asko 20005 front load washer. When the humidity is high, it buzzes but will not start. When I run a dehumidifier for a few hours it works fine.
The humidity will kill the control unit if you keep trying to start when buzzing. Make sure the humidity is as low as possible. These controlunits are discontinued, and impossible to get as sparepart!
However, this is the best machine ever made!!
Jun 28, 2014 | Asko W6021 Front Load Washer
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
Hello, I have an Asko washer model 20005 leaking water from both heating units where they attach to the drum. Both have been replaced and "not overtightened" by repair person, but still leak...
Only one answer really- recall the 'repair person'. He or she should have carried out the repair properly and completely and ensured that there were no leaks from the units after replacement. That's what you pay for.
Maybe they used the original washers and not new ones, for instance? Are both heating units 'OEM', that is Original Equipment Manufacturer (Asko or whoever actually makes the washer) or less expensive 'copies'?
Put pressure on ;-0)
John C
Mar 05, 2011 | Asko Washing Machines
I have the parts but need the instructions to install a new lock on my Asko frontload Washer/Dryer WD22M19.
Disconnect power then remove the clamp that holds the door gasket to the outer lip of the door opening. Once the clamp is off, peel the door gasket off near the door lock. Remove the screws securing the door lock to the front panel and take the lock out of the machine cabinet. Transfer the wires to the new lock then install it into place. Put the door gasket over the outer lip of the door opening and secure it with the clamp to complete the repair.
Oct 25, 2010 | Asko WCAM1812 Front Load Washer / Dryer
Where can I purchase a pump for my Asko washer 20005?
Ok, i have located the pump you will need. Simply click the link below to be directed to the purchase page.
CLICK HERE.
Nov 04, 2009 | Washing Machines
How do I remove the front control panel?
remove the 3 screws at the rear top to remove the top cover. you now have access to back of control panel. tou should see some plastic lugs sticking out through metal clips. you will have to force the lugs through the clips with a flat blade screw driver. be careful it is easy to brake them
Feb 13, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
