Question about Microsoft Xbox 360 Console
My 360 will not start and the power brick keeps going red as soon as i plug it in i brought a new brick and it still the same ,,,, can a faulty dvd rom cause this
    Novelist:
  • 168 Answers
This sounds like the lead free solder has failed at certain points shorting the power connection which can result in what your describing. below is a guide that might help.
This is a common fault with the 360, it says that its a "general hardware
failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat
and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 or even no sound but
graphics or sound and no graphics just like you are reporting.
Firstly get a spare AV cable from someone else, try this, if that does
the same then try a different SCART
input on the TV. if all this fails you need to fix your machine as it
WILL get worse
You will need to get a 3rrod repair kit or get someone to fix it for you,
there are guides available on the
internet. I'm in the middle of producing one right now that I will make
available free of charge for all fixya
members.
Linda
xboxrepairkit
Posted on Oct 10, 2009
My xbox wont turn on at all
Check power brick . If red your power brick may be faulty . unplug all cables and check power brick again . If green light is on the power brick your good if its red you will want to contact ms at 1-80004myxbox or 1-800- 469 9206 .
Aug 04, 2010 | Microsoft Xbox 360 Console
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Jun 14, 2010 | Microsoft Xbox 360 Console
360 won't turn on
Sounds like you fried your Xbox. You are right though, the lights should at least come on. You can try the new power brick and if that doesn't work then your xbox may have blown something, in which case your best and safest bet is to replace it. Sorry.
Jan 18, 2010 | Microsoft Xbox 360 Console
My battery light turned red and my xbox keeps crashing
You're battery light? On your controller? If you mean on your Xbox then you have the Red Rings. If you provide more information I can help you fix it.
Jan 15, 2010 | Microsoft Xbox 360 Console
Red light on power box for 360
i have to personally dissagree with 'wildbear' :-)
well not actually dissagree but i think the problem will be at lot less technical than all the writing he has done.
a simpler check.......does the 360 'switch on' ??
i assume with a red light on the power brick it dosnt ??
the problem is more likely a faulty pin (terminal) inside one of the USB slots you have been using for either a controller charger or wired controller (or a usb memory stick to play music thru ur xbox??)......plugging chargers/wired controllers in & out of either the 2 front slots (behind the flap) or the 1 at the back can sumtimes bend one of the terminals causing it to touch the outer casing of the usb slot ?? if it does this it shorts the board of the 360 which in turn stops u powering up the 360 all together :-(
one of the signs of this is a 'RED' light on the power brick & the 360 not powering up at all !! but sumtimes the power brick light will stay orange or even green.....even with this fault ! it dosnt always turn red !
One way to rectify it is (un-plug the powere brick from the mains first) & unplug ALL USB CONNECTIONS TO THE 360 !! (controller chargers ect) & try powering up the 360 !! (after plugging it back in)
if this fails ur gonna need a torch & a little screw driver (or tweezers) un-plug everything from the 360 & look inside ALL usb slots you have used ! check to see if any of the prongs have bent accidently whilst plugging in & out chargers ect ..... if they have straighten them so they are not touching any of the sides of the usb slot....
after doing this ...plug back in and 'hopefully' Whoooop Whooooop :-)
hope this helps ??
failing this it maybe as wildbear suggests & its a problem with the power brick altho i very much doubt it ?? they normally way out live an xbox !
remember thumbs up if this helps :-)
Jan 01, 2010 | Microsoft Xbox 360 Console
Power brick going red right as its plugged in
Sound like a short fet /L.D.O.R or a solder bridge under one of
the chips , you "worked" if you used a heat gun , there
is more than likely sever board warpage. A scratched
or broken trace will not trip the 1.8- 3.3 volt standby over current
(red light on the brick) it's normally a solder bridge.
but i could be wrong ,hard to tell with out line tracing
the caps with a scope.
Rob
Nov 11, 2009 | Microsoft Xbox 360 Console
The power brick turns red when i turn on the console
buy a new power brick or try replacint the cord between the wall and the brick
May 25, 2009 | Microsoft Xbox 360 Console
My xbox 360 power supply/brick goes from orange to red as soon as I plug it in the back of the console.
When the power box says RED, that means that the problem is your power supply, try another power box if you have a friend or relative nearby, and if it works on another brick that means you have to contact xbox support and check the warranty of your brick, but if its already out of warranty. You need to purchase a new power supply that costs $79.99 ( Only available through Xbox customer support ) - Shipping and Delivery will be covered by microsoft
Jan 30, 2009 | Video Game Consoles & Games
Power cuts off
Might be a faulty power supply mate , when you turn the xbox on observe the power indicator on the power brick.
Green means its okay
Amber means the console is in standby
Red means the Brick has had it.
Try a friends power brick to see if it does the same.
jonno
Sep 03, 2008 | Microsoft Xbox 360 Console
Power brick red light
yeah you definitly need to have a uk to usa power converter. you guys run on 220V which would create way more current then needed which is why the power supply blew. I hope you didnt fry any internal parts in the 360. You need to get a power converter that gives you 120V.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
