Question about HP (194989-001) (194989001) Power Supply
Pin connection of power supply HP P/N 194989-001
I need to use this power supply for other application but I d'nt know how
connect the pin to power on the output (I need +12 volt on).
Tank you for help.
Salvo
SOURCE: need a d520 sff motherboard layout
mine was do- the same. pin 2 is next to the dim slots its white. i con-ed a 12 fan to it. the fan dont spin i dont get the mess any more i am look for the book to get the jumper set- as well. so i can take the fan off. small 12 v fan
Posted on Feb 04, 2009
aparsons
  • 3 Answers
SOURCE: HP zd8000 laptop power supply
I found the solution - and implemented it, it works. The blue (ID) line needs to show 7.5v. The simple way to acheive this is to simply put a 47k resistor from the +19.5v line to the ID line. Apparently there is a pull down at the computer end that means it ends up at 7.5v.
I cut the cable about 6" from the old HP power supply. I then soldered a female power socket onto the loose cable and soldered the 47k resistor between the ID line and the +19.5 line. I then plugged this onto my two pin power supply and the plugged it into my computer. It works very nicely.
Not wishing to junk the HP power supply unecessarily - it was still producing the 19.5v - I then soldered a power plug onto that ignoring the ID line. That now works as well. It seems that the circuitry that provided the 7.5v ID voltage in the HP power supply became flakey. I could have just opened up the power supply (I have already done that) and disconnected the blue line from the circuit board and just tied it to the +ve line via the 47k resistor and then wrapped it with the usual insulating tape.
Posted on Apr 03, 2009
heavymetal77
  • 721 Answers
SOURCE: Want to use the atx-300-12z as a hobby power supply. Need 12vdc.
You're asking for a fire or just burning out the power supply. But,at your own peril, check the yellow wires for 12v or buy a power supply test adapter from ebay. It bypasses the power switch usually done by the motherboard & will fire up the power supply like it was connected to a board. Then test the wires for 12v. Should be any yellow wire,red is 5v. Green is 3.3 or 3v.
Posted on Jul 22, 2009
SOURCE: POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Posted on Aug 28, 2009
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
Power supply was removed and don't no where to put wires/acer aspire
cable has 20 or 24 pin group it will only go in one way
Apr 16, 2014 | Intel Motherboard
New GA-990AX-UD3 motherboard will not boot
You really should take that Power Supply, and use it on grandma's computer.
The 8-pin EPS +12 Volt power cable was brought out, to provide more power To the motherboard AND processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
The 4-pin ATX +12 Volt power cable has TWO yellow wires.
Yellow wires are 12 Volt wires. (And two Black ground wires)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
In the motherboard manual, does it say, "Yes Tom. Go ahead and use a 4-pin ATX +12 Volt power cable. We don't care. We just use an 8-pin EPS for fun."
[ This is an 8-pin PCI Express power cable. Completely different,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8 ]
The motherboard probably uses 150 Watts by itself.
No Ram Memory, no CPU, no fans, etc.
The CPU could use up to 125 Watts of power. Just depends on what AMD, socket AM3, processor you are using.
Now to graphics card's power;
The most Wattage a PCI-Express x16 slot can deliver is 75 Watts.
The most power a 6-pin PCI Express power cable can deliver is 75 Watts.
8-pin EPS +12 Volt power cable? 150 Watts.
When buying a Power Supply you should calculate all components needing power,
http://extreme.outervision.com/psucalculatorlite.jsp
,then buy a Power Supply that has AT LEAST 10 percent more power than needed. Easier on the Power Supply.
Also a computer will NOT use more power than it needs.
10,000 Watt power supply, (Exaggeration ), and the computer only needs about 100 Watts for surfing the internet?
Computer ONLY uses 100 Watts.
Due to the price, the above, and the availability, you should use a 500 Watt power supply at least.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
http://www.amazon.com/StarTech-6in-Pin-Power-Adapter/dp/B002O21XHQ
Or use it on yours if it has enough Wattage.
Back in the day, the motherboard didn't need to supply that much power to components on it.
More powerful Processors, Ram Memory, and graphics cards, brought the power needed, up.
A 4-pin ATX +12 Volt power cable was added for the motherboard. Then 6-pin PCI Express power cable for graphics cards. Then the 8-pin PCI Express power cable for graphics cards. Lastly the 8-pin EPS +12 Volt power cable.
(Better make sure the Power Supply you have is good, if you wish to use the above power adapter cable. Nothing like having a Power Supply with a weak voltage power rail, and a new build, to pull your hair out on )
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Out of the motherboard manual Page 23,
"With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard. Before connecting the power connector, first make sure the power supply is turned off and all devices are properly installed. The power connector possesses a foolproof design.
Connect the power supply cable to the power connector in the correct orientation. The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start.
To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2012 | Gigabyte Technology GA-990FXA-UD3-...
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
Power is not comming into the printer
No power to the printer. 1) Either the power adapter is not connected properly.Remove the power cord from main power outlet and connect it to any other electric outlet.Also at the back of the printer there is a socket where the power got get connected.Remove power wire from there too and reconnect it. 2) If the problem is not solved then there are two possibilities:-- A) The power cord is faulty and needs replacement. B) Or the printer circuit board is got short and it has to be replaced. ------------ In both the cases A as well as B you need to get the fault checked by other spare power adapter or power supply board in printer.At local printer repair shops they have this parts in spare.They will get the fault checked and let you know that which part has to be replaced.Either the power adapter or power supply board.The cost of new power adapter is near to $10 and cost of new power supply board is near to $40. -------------- One more thing i want you to check is.In your printer power adapter there is one three pin power wire is connected.That three pin power wire wire goes from main power outlet to the printer adapter.In some cases that three pin power adapter gets faulty.If that three pin power wire is faulty then the cost of that power wire is just $2.So get that three pin power wire also checked. To see how this three pin power wire looks.See the fig below:--- helpmech_1.jpg
If this wire is faulty then its not much costly. ----------- This are all the possibilities that you will have to get checked.To get the fault confirmed.Thanks.Helpmech.
Dec 04, 2010 | HP DeskJet F380 All-In-One Printer
I have unpluged the 20 pin ATX Power Connector on the PTGD-LA motherboard, there is a 24 pin plug, I am not sure where to plug it in. I can only find manuals for the PTGD1-LA which shows a 24pin/24plug.
If the motherboard has a 24-pin socket, you need a 24-pin connector on your power-supply.
If the motherboard has a 20-pin socket, then only 20-pins from the connector need to be connected to the motherboard.
Oct 22, 2010 | HP Computers & Internet
Sep 22, 2009 | HP Compaq Business Desktop d330 Slim Tower
Motherboard has a 24pin connector for the power supply, but the connector on the power supply has a 20 pin connect? How do I connect it correctly
i presume that is a pentium 4 or newer motherboard. you will need a power supply that has at least one or two of the small four pin connectors as well... generally if it has that the extra four pins slides onto the 20 pin connector on one side and that makes up your 24 pin connection.
Sep 10, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Hercules switching power supply 500 wat max
yes 20 pin connecter power supply is ATX(advance technology extended )power supply and old which was low watt and 24 pin is EATX (enhaunced advance technology extended) power supply is new and high watt so 4 pin connecter can be detached from 24 pin connecter and can be fitted in 20 pin connecter
Oct 18, 2008 | Guillemot Hercules Dual Fan ATX 450W Max...
Dead new motherboard
Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
Mar 06, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
