Question about John Deere Garden
Have a john deere 115 and the drive belt came loose and jammed under rear end cooling fan how do i replace drive belt
  • 472 Answers
Ya that be were id start
Posted on Oct 05, 2009
Belt diagram for john deere 115
Follow the link and then shchol down to the 115 model John Deere Belt Routing Guide
Jun 27, 2017 | John Deere Garden
I have a John Deere LA 115 hydrostatic transmission that's going on 8 years old. When I crank it there is a noise that almost sounds like something is loose under deck. When I press clutch, it stops. What...
Check drive path for the idler pulleys. One is a flat and the other is V type. The bearing go dry on lube and require replacement,
See Circled items below.
Mar 31, 2015 | John Deere Garden
John Deere EZ track Z425 the belt that makes it go forward or backward must of came off or is loose, how do I fix it??
The John Deere EZ Track does not use a belt to drive the machine. This is a hydraulically driven machine. If you look at the back of the machine under the cowling next to the rear axle, you will see two metal rods sticking out at you. The ends of the rods are bent downwards. You can pull the rods out towards you or push them in. When the rods are pulled out, the machine will not drive because the rods are drive disconnects. If you push the rods in, you should be able to run the machine.
Aug 04, 2014 | Garden
Trouble shoot a John Deere lx 188 clutch?
Sounds like new belt is jammed or something is out of place. Turn by hand and find out where the problem is. You can tell where the belt is stuck or jammed. Pull the key before you mess with stuff underneath the unit. I installed my belt the wrong way on my unit and ruined a new belt and it would not shift.. The shifter rod could have been dislocated when you installed the belt also.
Jul 27, 2014 | John Deere Garden
My John deere l118 riding mower goes slower and slower. suggestions please
Firstly remove the battery and battery tray and clean all grass and debris from around the hydrostatic drive and cooling fan. Secondly check the drive belt idler pulley, arm and spring for free travel. Hope this helps, regards Phil.
Jun 18, 2011 | John Deere 22HP Hydrostatic 42" Riding...
My johnb deere L120 engine runs fine, but after about 20 minutes the tractor slowly stops moving, i dont know if this is a drive belt problem or something wrong with the hydrostatic?
Hi, most likely the hydrostatic is over heating. Remove the battery and battery carrier. From here clean any grass and debris from the hydro and cooling fins, also check the cooling fan condition. Under the mower check the idler pulley on the hydro drive belt is travelling freely. Hope this helps, regards Phil.
May 08, 2011 | John Deere Garden
How to ajust drive belt 145 john deere
It is better to replace and not adjust the wheel drive belt, too loose and it slips, too tight and you ruin very expensive bearings YOU can not replace...Belts are cheap, bearings are very expensive!
Jul 14, 2010 | John Deere 22HP VTwin 48" Riding Mower
I can't get the new drive belt on my L110 john Deere riding mower
If the fan is damaged replace it you can bend the gard back ing the correct shape.
Aug 23, 2009 | Garden
Gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Dec 28, 2008 | Garden
Garden Logo
414 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
