Question about Panasonic Microwave Ovens
NN-A774SBBPQ Invertor & Cat-Clean model.
Quietly popped an internal fuse (10A) during use and went dead. Replaced fuse, display/controls working fine but died when START pressed. Replaced fuse again, removed blown/broken heat element in top (grill?) insulated the wires to that - now not blowing same fuse but still dead. Is there a 3rd fuse position I've missed? HELP!!!
    Scholar:
  • 78 Answers
No 3rd fuse as far as i know just the two on the mains pcb and the plug i would test all three fuses again but if the short has gone back up to the control panel them that might be why its not coming back on if it has blown the control pcb it will show up as ablack mark on the pcb sorry cant be nore help its the sort of thing i would need to see as it could be a door micro switch as well gd luck dont forget to unplug the unit
Posted on Oct 22, 2009
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Dec 20, 2014 | Panasonic Genius Prestige NN-CD989S -...
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Main fuse blows when I press start on panasonic nn-255 microwave opened up microwave and see 25 ohms on cn702 of invertor circuit board, what's normal? This would appear to be a short to the 120v supply,...
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Apr 17, 2010 | Panasonic NN-S255 Microwave Oven
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
Microwave Oven has died
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Sep 30, 2009 | Microwave Ovens
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Jul 29, 2008 | Panasonic Microwave Ovens
Panasonic NN-S789WC - No power on Display, Fuse OK, bulb Lights
The fuse will be a white or gray ceramic fuse, and you really can't tell if it's blown without actually measuring it. If a new fuse blows when you hit START, you probably have a shorted high voltage capacitor. If you have replaced the fuse and still have no display, then it sounds like there's a problem on the control board. The control board has a built-in surge protector which can short (and smoke) and when it does, it will cut the power to the control board, but not blow the fuse. We repair these nationwide for only $39.95 postpaid. If you or a friend want to check it out or send the control unit in for serivce, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 02, 2007 | Panasonic NN-S789 Microwave Oven
Microwave Ovens Logo
126 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
