Question about Fuji FinePix A210 Zoom Digital Camera
Camera screen says "card not initialized"
Camera screen says "card not initiallized" has been working fine till now. Any suggestions I tried formating via school computer but that told me I did not have permission to do so. We have been using and downloading pictures no problem, can you help thanks
Sdhc card was workin/g and it said card not initialized
  • turn off you camera and remove the memory card
  • reinsert the card and turn on your camera
  • re-format the card (low level) using your camera . / or under menu search for format or initialize
Aug 27, 2014 | Cameras
I have not used my Fuji Finepix 6800Zoom for many months so I charged it up and now when I turn it on 'ERR CARD' is displayed in the round screen. If I press Menu and then Back !card not...
May be you inserted a memory card formatted with your PC. Format the memory card using the Format function in the camera menu. Format function can be found in the setup menu of the camera.
If this does not work, try replacing the memory card.
Sep 02, 2011 | Fuji FinePix 6800 Zoom Digital Camera
My sd card wont read. it says that its not initialized. i flipped the thing in the sd card but nothing changed. how do i get my card to work. it worked fine until i put the sd card in the printer over...
Had you ever initialized (formatted) the card, especially when you first got it? If not, an unformatted card will work fine initially, but almost always corrupts with time after many pictures are added. To prevent this issue permanently, you should always format a new card. But note formatting will erase the card! If you haven't saved your pictures yet, and you're having trouble locating them on the card with your computer, see this article. After you've recovered and saved your photos, format the card IN THE CAMERA using the camera format feature (look for it in its menus). This will rejuvenate the card, and prevent this from happening again.
Jan 09, 2011 | Cameras
The camra works fine until i put in the memory card,when i put in the card it pops up E53 and wont do anything-to get that off i have to take out the card and batteries and its fine again-what do i do?
Without knowing the camera make and model I can only suggest you check your owners manual on how to format your memory card, your manual may also call it initialize.
I'm also going to include a diagram that shows the SD sliding lock, if this lock is in the lock position a whole sea of problems can "pop" up. the lock function is there top protect pictures or files on the card from being deleted by mistake. However sometimes these annoying little trouble makers get pulled down into the lock position.
Here is the diagram. Remember check the lock and then format/initialize your memory card also after each time you download your images from the camera or the optional card reader you must format the memory card to have the camera properly function with the memory card.
Hope this helps have fun with your camera
Dec 30, 2010 | Cameras
Camera says card not initialized
Is there a format option on the camera?
May 09, 2009 | Cameras
My xd-picturecard is not working in camera saying that card is not initialized My memory card worked fine the first time I took pictures with it, but after taking it out to upload them and then replacing...
see if there is a format highlight in menu of camera-this will format card to camera and should make it compatible-format will delete all data from card!
May 21, 2008 | Fuji Finepix F50FD Digital Camera
Memory card problem
go into settings of your digi cam and use the format option , thats should solve your problem
May 20, 2008 | Fuji FinePix A605 Digital Camera
Finepix a330
What type of xD card did you buy?  It needs to be a plain xD card with no letters before the file size or a type "M" card.  For type "M" you will need to upgrade the camera's firmware.
http://www.fujifilm.com/products/digital/download/a330/fupd.html
This type of camera can't use type "H" cards, so cards like "H512mb" aren't going to work.
To initialize a card choose Menu. Arrow over to "Set", then arrow up to choose "Set-up". On screen "1" of the Set-up, arrow down to choose "Format".
This will ask you to erase all the images from the card, and format it.
Just today I upgraded my camera firmware to accept a type "M" card, initialized the type "M" card after that - and now it's working fine!
Reply back if you need more help. -Kelly.
Nov 21, 2007 | Fuji FinePix A330 Digital Camera
Memory Card
Format the card in the Camera- read your manual
Jul 31, 2007 | Fuji FinePix A500 Digital Camera
SanDisk Ultra IICF 2.o GB
on pc, try using the utility [format] when card found under "My Computer"
May 20, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix A210 Zoom Digital Camera Logo
108 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
