Question about Vertex Radio Communications
VX210 GIVES 3 TONES WHEN PTT PRESSED. WHAT
VX210 GIVES 3 TONES WHEN PTT PRESSED. WHAT DOES THIS MEAN?
    Master:
  • 623 Answers
Check to ensure you don't have the "WIRES" setting enabled. A common issue with Yaesu radios. You can turn it off with a combination of a "F" key press and the button that has a little symbol that looks like an atom with electrons orbiting it.
Posted on Oct 30, 2013
3 Suggested Answers
dobhan
  • 105 Answers
SOURCE: Kenwood ts-450s - cannot tune and no ptt
with this kind of problem i would suggest to send it to kenwood service center coz the is not easy,it needs a qualified technician....
Posted on May 09, 2008
This is usually due to a stuck or shorted ptt line. I have repaired a couple of these and it was the same component each time. The packet TX transistor Q65 shorted causing the radio to power up in TX inhibit mode. Transistor Q65 is located on the underside of the IF board under the ACC 2 connector. This switching transistor is used only for tx (pin 9 of acc 2) and no other circuits depend on it. It can be removed completely if you don't mind not having ptt on acc 2.
This seems to be a common problem lately, I hope this helps you.
Posted on Aug 09, 2011
Is there a factory reset for this model?
In general, when a radio turns itself off when the PTT button is pressed, it is a sign of a bad or poorly charged battery. Try trading the battery with a known good unit and see if the problem is solved. If so, replace the battery.
Best regards.
May 20, 2015 | Radio Communications
PTT button on RDV 2020 is hard to push
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Best regards.
Apr 18, 2014 | Motorola RDV2020 Two Way Radio2 VHF 5...
Puxing PX-777 PTT problem
It sounds like a PTT fault as presumably the headset has its own
ptt?
Try a reset?
Jan 25, 2014 | Radio Communications
Earpiece
Be certain your radio is turned off when you initially plug in the earpiece, then after turning on the radio, immediately press the PTT on the earpiece. On most models this initialization syncs the earpiece PTT to the radio. We have experienced a few older model radios which require the radio's PTT to be pressed once, followed by the eapiece's PTT, to initialize, but this is rare. The other possiblity is the earpiece was not made to match the radio you are using it on. The position of the rings on the 2.5mm and 3.5mm jacks can make a difference between models of radios.
Best regards.
Jun 27, 2012 | Binatone Terrain 750 Twin - Black
To turn the tlk confirmation tone off... it does not work holding the - sign and turning it on now what?
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Oct 13, 2010 | Motorola Talkabout T6500 (7 Channels)...
Hi I have the T5622 talkabout with a PTT headset. I can transmit OK but I am not receiving anything other than a ''click'' when the other person transmits. I have tested the headset and I am able to recive...
Here a few thoughts which come to mind.
1. You do not mention whether the radios communicate with the headset no on the radio. I will at this point, assume they do.
2. Be certain to have the radio SHUT OFF when plugging in the audio device.
3. Check your VOX settings. It could be your radio is going into VOX mode.
4. Only use the PTT button on the headset. Do not press the PTT on the radio at any time while using the headset.
5. Check that you have CALL TONES shut off.
6. Lastly, if nothing else works, go back to a basic mode, and set both radios where there are no special features turned on. ie turn off CODE, Qt Filter, VOX, Call Tones, etc.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Feb 05, 2010 | Motorola Talkabout T5720 (7 Channels)...
Can't download mp3 songs from internet gives error bad gateway
Download ? what do you mean are you removing mp3 tones from your fone or.... ?
Jan 07, 2009 | Motorola Lands Phones
Motorola T5100 Radio
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 11, 2008 | Motorola Talkabout T5100 (14 Channels)...
Ring tone thingy
To set a call tone:
Sep 07, 2008 | Motorola Talkabout T5420 (14 Channels)...
Apr 26, 2008 | Radio Communications
Radio Communications Logo
184 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
