Question about Maytag Neptune MAH5500B Front Load Washer
Shows Lr and stops with 9 min. left ,,,davidlcoppockjr@gmail.com
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question ^&$^
Posted on Oct 01, 2010
How to stop my gmail address from showing up automatically on this computer
Follow the suggestions here, and make sure you uncheck 'stay logged in' https://support.google.com/accounts/answer/2917834
Feb 27, 2015 | gmail.com
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
My washer stops working when there is between 8 to 11 min left in the cycle then gives me a Lr on the digital readout. It never finishes the last spin. I am not sure if this is the model, I do not have...
Hello, Thank You for using FixYa. I will be helping you today.LR means locked rotor. Usually when this happens it needs a new motor or motor conversion kit depending on the model.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer stops and the display shows Lr.
This is your control board that is going out on this washer. It is simple to repair and you can save a lot of money by making the repair on your own.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and let us know the brand and model number, and we will get the correct part out to you asap.
You can contact us from 7 AM until 9 PM CST Monday through Saturday.
We want to get you washing your laundry again soon.
Happy Holidays to you! Thanks, Ella
Nov 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
When I turn on the unit (new batteries installed) it shows 9 - 11 satelites, but it doesn't acquire any of them. Any suggestions?
if it shows 9-11 satellites, it has aquired them. let it sit for a bit until it gets the proper data for them. if it has just been turned on for the first time or is left off a lot it may take 3-5 mins to figure out its locations.
Nov 10, 2009 | Garmin GPS
Remove ''LR'' from display on calc.?
I am sorry but I do not quite understand by the LR showing in the display.
For the FX-115ES, the only instance where the L and R appear is in the solutions screen.
When you use the Solve( function, the calculator searches for the solution. When the solution is found, the screen displays
(actual exemple)
Y=3*X^2-2
X= 0.8164965809
L-R = 0.
The L-R =0, shows that the precision of the solution, Left member -Right member =0.
To clear the screen you press [AC].
Hope it helps.
Nov 09, 2009 | Casio FX-115ES Scientific Calculator
Some unknown mails to unknown address forwarded from my account
I recommend you to delete it it look like virus whenever you receive an e-mail that you dont recognice I recommend you to delete it if you don't your computer will start acting slower due to the virus.
Your Rating is very important for me
"Was this helpful?"
May 23, 2009 | Google Gmail
LR brake lite and turn signal
Hi, Giterdunn2 I am sorry you can't find the first and best tool you ever bought for your Boss Hoss but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Troubleshoot Repair motorcleTurn signal light
DIY Troubleshooting Motorcycle Electrical Issues
http://antakesuma.xyz/fds/b/boss-hoss-bhc-3-ls2-2008-custom-cruiser-v8-automatic-repair-manual.pdf
https://www.bosshoss.com/parts.asp
Boss Hoss Cycles Contact Us
May 21, 2009 | 2001 Boss Hoss BHC 355 Hp
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
