Question about Lexmark W840 Printer
How reset count pages - Lexmark W840 Printer
Page count
The E232 cartridge uses a chip to set the page count on the printer. To reset this you need to replace the chip on the cartridge. Your friendly cartridge remanufacturer has access to the chip. They can source one for you.
Oct 02, 2014 | Lexmark E232 Laser Printer
HOW TO RESET PAGE COUNT TO ZERO
The page count on these units is a lifetime count and does not get reset. Larger machines like th P4015 have a maintenance count which is reset when the fuser is replaced.
Aug 08, 2014 | HP Laserjet Printer P2035 P2055 Laser...
T632 reset count
Enter diagnostic mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when Performing Self Test displays on the operator panel.
Once you're in diagnostic mode, go to Printer Setup > Page Count.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
Jan 30, 2013 | Lexmark T632 Laser Printer
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
1. Select Reset Maintenance Count from the Configuration menu.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How to reset PC kit e332n
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
Oct 01, 2010 | Lexmark E332n Laser Printer
How do i reset the maintenance count?
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
How do I reset the page count on a HP Laserjet 4345mfp? Cheers Michael
the total page count cannot be reset, if you wish to reset consumable counts replace relevant consumable. thanks
Oct 05, 2009 | HP LaserJet 4345mfp Printer
Lexmark W840 Printer Logo
117 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
