Question about Refrigerators
Water dispenser is not working
It's a lg stainless steel fridge with french doors with the water dispenser on the left side, the freezer is in the bottom with an ice dispenser inside it....
We are having problems with the water dispenser, it's not working, and we don't know what the problem is?!?
  • 4,059 Answers
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Oct 05, 2009
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
Water is dispensing very slowly and I just
yup,
i would turn your freezer down a few degrees, you are more than likely expeiancing, whats called migration frost, cold air from the freezer, could be freezing your water resivoir or the line from it
causing bad pressure
Oct 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Water dispenser not working in my Maytag Model #MFD2561 HES
Hi. Do an Internet search for Maytag recalls. Your fridg. may be on their list. If this solution has assisted you, please rate it. ricardok45.
Dec 27, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker works but water won't dispense
There is a know defect with the freezer side door. read more at http://www.houstongofarappliancerepair.com/Refrigerator.html
Also, If you call and haggle GE they may send you a new freeezer side door. Or, You may actually try turning fridge off, leaving door open for about 4 hours and then try it again. As strange as this sounds it has worked for some of my customers.... When "air-bubbles" get into that line it can freezer inside the door a small section of water line because the insulation in freezer side door isn;t thick enough... More can be read on this problem at http://www.houstongofarappliancerepair.com/Refrigerator.html
goodluck...
Dec 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
1,549 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
