Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I need to replace the lid switch on my Kenmore 110.20702990 Washer. I have the new switch. The lid does not "pop" off. How do I get to the wireing area where I must plug in the new switch?
    President:
  • 1,937 Answers
This is a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20702990
See the sections on the top and cabinet and the control panel.
Also see the following on how to access the control panel. You don't need to go through the rest of the document to pull clutch, transmission etc.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 05, 2009
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Instructions to replace 3949238 lid switch?
remove the two screws that hold down the top console,flip up the console,with a screw driver pop the two metal clips and the wire harness closest to the right clip is the lid switch harness.unplug that,now remove the two screws that hold the switch in place where the lid closes down.tilt the frame forward a little,you have to remove a 5/16 inch screw that holds a ground wire in place near the switch,pop out the wire harness out of the two clips,use a screw driver to bend the clips so you can get the wires out and then push the two plastic side holders in and then push the harness out of the top panel.then put the ground wire screw back on,screw in your new switch,stick the harness behind the clips,pop the white harness piece back up throught the top panel,realine the panel,pop in the two metal clips,plug in the harness to the switch,flip down the console and screw it down and you are done,when you go to put it back together watch out for the clear plastic line going to the pressure switch.if you knock that off the washer will flood over,most likely you wont even move it but i've heard it happens.good luck
Jan 29, 2011 | Kenmore 22422 Top Load Washer
Agitation does not stop when lid is open... Kenmore 20172 Top Load coin-op Washer needs new lid switch? Cost? Easy to Fix? Do I need a expert to do? Thank you...
sounds like the lid switch is jammed on- you can try to spray it with WD 40 or replace it it usually requires taking the machine apart to get at the wiring. Easy fis, just need patience. the switch should be able to be ordered online.
Oct 21, 2010 | Kenmore 20172 Top Load Washer
When you push start button error message says lid. Washer will not work.
Lid switch failure or out of adjustment, if your handy pop the top and adjust or replace the lid switch, or call your local authorized Kenmore servicer.
Good luck !
Jan 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Require a new lid switch to fit a model 22622100 type 111 Kenmore washer, also require a service manual to find out how to remove the washer top to instal the new switch
http://www.appliancepartspros.com/part_details.aspx?part_id=3100001&rdr=%2fmodelsearch_model.aspx%3fmodel_id%3d415134
Check out that link for the switch.
As for the washer top, you don't remove just the top, you remove the whole cabinet. Remove the two end cap trim pieces from the control panel, (just pry them off) remove the two screws securing the panel to the cabinet. Flip the control panel back on it's hinges. Unhook the lid switch wire harness, and use a screwdriver to pop out the two gold clips that secure the cabinet to the back panel. You should now be able to tilt the cabinet slightly forward (towards yourself) and pull off the base. You now have full access to replace the lid switch.
Dec 30, 2009 | Kenmore Washing Machines
Can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore goes through all the cycles but will not spin!
Hello, ok washer not spinning is 1 of 2 things. First see if lid switch is clicking, do this by shutting and reopening the lid …do you here a click click sound. If you do then more then likely the lid switch is good. If not then replace the lid switch by unscrewing the 2 screws by the lid switch, unplug washer, pull switch out, it will come out about 4 to 5 inch’s, cut the 2 wires close to switch and then strip each wire back about ½ in. when you have the new switch cut wires 6 in from new switch and strip wires the same. Wire nut the 2 wires together and then wire nut the other two wires together. Reverse steps to put back in. if it is not the lid switch then it is the coupler. This you will need a technician for unless you are somewhat mechanical. If so you can look up how to do this. Thank you
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer
Most likely you need to replace the lid switch.
Open the lid and make sure the actuator that pushes the switch is still attached to the lid. Use a pen or screwdriver to depress the switch through the hole in the top of the cabinet, you should hear a click as the switch closes. I usually find that the switch has actually broken off from the cabinet and is hanging loose in the machine.
To replace the switch
Remove the screws that hold the console to the cabinet. Flip the console up and back like opening a car hood. unplug the wire connector for the lid switch. Pop out the two clips that hold the cabinet to the rear panel of the washer. The cabinet will tilt forward and slide off the machine base. You can now replace the switch from inside the cabinet.
If you need further help, please post the complete model number from the washer so I can see exactly how your washer is set up.
Mike
Apr 11, 2008 | Kenmore 22422 Top Load Washer
Lid Switch replacement
ok " unplug washer from wall , ( can not stress enough that there can be no electricity running to that machine)
depending on the washer most have screws on the back at top, you will have to take them out, ok so far , most lids have metal clips holding tops on , pry top up and it will pop loose.
got that far, now look at inside of the top where lid opens and you will see a small micro switch
two screws hold switch in place, electrical wires to switch are cliped on they will pull off
take micro switch to appliance parts store they will match it
take make and model of washer with you
screw in new micro switch and attach wires to switch , and snap
washer cover back on, attach screws to the back , and your all set.
see you can do it
Jan 06, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
78 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
