Question about Nortel Meridian M7208 Corded Phone
Meridian M7208. I managed to reset the default
Meridian M7208. I managed to reset the default speed dial button to a conference button. I wilsh to reset it to speed dial. Since I have no idea how it happened to begin with I do not know how to get it back!
    President:
  • Nortel Master
  • 860 Answers
Press feature *3, press the button you want to program back to speed dial, and press feature 0.
Posted on Oct 06, 2009
Testimonial: "It worked!"
Not the normal voicemail problems
Before you can do anything you need a M7310. Programming a Nortel voice mail requires M7310. It uses the 3 soft keys under the display to program it. You can get one cheap on EBAY. Next you need to find out what type of Voice Mail System in connected to your Nortel phone system. Below is a link to a Older StarTalk manual. You may have a StarTalk, StarTalk Flash, or a Call Pilot.
http://www.myuserguides.com/Nortel_Norstar_Startalk.pdf#page=15&zoom=auto,-69,407
Below is a link that tells how to reset the System Manager Password.
Reset Admin Password Norstar Meridian and Nortel BCM Help Guides
The default code and password for System Admin is F983 and 1020000 or 1021111. The photo below shows a system admin programming tree. Hope this helps
Charlie
Apr 10, 2015 | Nortel Norstar M7208 Telephone
Want to change dial pulse out dialling to DTMF tone dialing
unless your phone supports that (and has a little switch somewhere), you just can't. Get another phone, sorry !
Jan 22, 2014 | Nortel Meridian Norstar M7208 Mics Cics...
When I unplugged my phone and plugged it back in, when I push my speed dial button it picks up a phone line now. How do I reprogram that button to be speed dial?
Feature * 3
Press that button
Feature then 0
If still an issue then do F * 0 and press that button, need to know what is says on the display as you cannot override Lines,Intercoms, Handsfree, Huntgroup keys.
Dec 07, 2012 | Nortel Meridian M7208 Corded Phone
Nortel Meridian M7208 page not working...
Press Feature * 3
press the 5th line key you want to use for paging
enter the page-all code (feature 601-603 as you wish)
Aug 20, 2017 | Nortel Meridian M7208 Corded Phone
I don't know how this happened, but any button I touch automatically calls a specific phone number, even if I use the intercom... It seems that the phone has been programmed to dial this number by...
Hi Evygal,
There is nothing to worry about it because this phone supports a speed dialing feature , which means that you can program the numbers in a way that just pressing them in a specific way usually for some more time than a usual press of a button will automatically enable the speed dial function and the phone will call the number that has been programmed on the digit.
A good idea to not face this problem is to quickly remove the finger off the button when you press it , because keeping it for long , just as long as one sec can enable this speed dialing feature.
Hope that helps ..:) Let me know in case you have any queries, would love to help you.
Sep 12, 2011 | Nortel Meridian M7208 Corded Phone
No dial tone
try another M7208 phone using the same connection including the same line cord, if that phone works then the first phone is bad, if not then look for trouble at the outlet or line cord
Dec 08, 2010 | Nortel Meridian M7208 Corded Phone
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
No dial tone
It sounds like you have the wires hooked up wrong. Check both ends of the wire.
Jun 01, 2009 | Nortel Meridian M7208 Corded Phone
SCREEN NOT DISPLAYING NUMBERS
If you haven't already tried it, unplug the phone, press a couple of buttons, then plug it back in so it resets. If the boxes still appear, try adjusting the display contrast. Press Feature-*-7 to get to contrast setting and then press 6 or 7 to set mid-range contrast.
Mar 30, 2009 | Nortel Meridian M7208 Corded Phone
Unable to use conference button
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
Nortel Meridian M7208 Corded Phone Logo
809 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
