Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Schematic looking for a schematic ,vacuum isn't sucking and is going really slow
  • 1,673 Answers
Re: schematic
Sounds like the motor has gone bad. But you need to go to, click on the part link, put in your complete model number, usually starts with 116.************. Then a parts list will come up and if what you need is there, you can order it thru Sears. Sometimes underneath the rear top cover, is a schematic
Posted on Jan 22, 2008
0 characters
3 Points
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
The bottom of the vacum isn't sucking
My dyson animal seems to have a blockage in the base it makes I sucking noise then pops the sucks ion threw the wand is fine
Oct 22, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
I have a sharp twin energy, the hose isn't sucking very well, and just today it had a burnt plastic smell
This sounds like something is plugging the air flow. You need to take apart until you find it. Air flow also cools your unit.
Jun 09, 2011 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Not sucking - not self-propelled.
Problem 1: it could be the transmission causing it not to be self propelled.
Problem 2: Have you checked for clogs in the system?
Aug 11, 2009 | Vacuums
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Jun 16, 2008 | Dirt Devil Vacuums
Not sucking up
Not sucking up
Posted by Smudge935 on May 02, 2008
Hi, I have a Dyson DC05 and initially it sucks up ok then stops. On investigation the dust particles are ending up in the pre-motor filter instead of the canister.
I have checked for blockages, and cleaned filters. Any ideas????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Something is blocking the path of the dirt to the canister and it should not be going directly to the motor filter (diverter valve) that is supposed to be a backup just in case. So that the motor does not burn up, please check with you local vacuum cleaner dealer for a schematic or a product breakdown.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Contact Us
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
352 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
