Question about Acer Aspire 3610 Notebook
Screen flickers My screen flickers on my acer laptop
  • 3 more comments
  • RoyKindell Jul 18, 2008
    My Acer Aspire 5000 laptop screen starts flickering ten goes completely white.
  • vis_lus Dec 29, 2008
    Inpredictable flickering on my Acer laptop which is with 17" WXGA + Acer CrystalBrite LCD. What is the solution for this problem..?
  • zy_deco Apr 02, 2009
    My Acer Aspire 4315 does the same thing. The screen flickers, and then
    it goes completely blank white. If I hit Ctrl + Alt + F11 it comes
    back, but it's only a temporary fix. Also, if it helps at all in
    answering my problem: If I attach an additional monitor to my computer,
    it does not go blank when the laptop screen does.
  • Anonymous May 06, 2009
    when the acer boots up the screen turns red then it goes black....I can see text that's written white (barely) other than that ...the screen is black or very dim?
  • Anonymous Mar 12, 2014
    lenovo laptop G505 will not connect properly to the NEC projector screen in classroom, it will connect, flicker and then disconnect.
  • 383 Answers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
My aspire 5830t screen flicker at startup
I suspect the backlight or inverter may be faulty. Check on flea bay for replacement prices.
Dec 21, 2013 | Computers & Internet
Acer 7530 screen flickers
hi
it flickers due to incorrect frequency setting.. LCD should be set to 60Hz. go to desktop, right click, graphics properties, display settings and set to 60Hz
Jan 02, 2012 | Acer Aspire 5630 Notebook
Acer laptop screen flicker. intermittent. more at start up
Hello,the flicker on your laptop is as a result of a faulty screen or screen connector(Flex).have an authorized service personnel have a look at it.thanks
Aug 20, 2011 | Acer Computers & Internet
My acer aspire 7535-5020 screen flickers sometimes the screen will go completly white
First you will need to determine if there is a problem with the laptop screen or the video card.
Plug in an external monitor to your laptop and use your laptop, if the screen on the external monitor flickers the same way your laptop screen flickered then there is a problem with the video card and you will need to repair your laptop. This is considered a major repair because the video card on the laptop is usually embedded into the motherboard and will be expensive to replace.
If the screen does not flicker then the connection from your laptop to your laptop LCD display might be loose. You will need to remove the cover of your laptop and make sure the connection is firm, as well as make sure there is no damage on the connector or wires.
Hope this helps.
Mar 16, 2011 | Acer Computers & Internet
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
Flicker
if you have screen Flicker, this could be several Things. Faulty or Failing Inverter Board, Or tft screen tube failing ( usually determined by occasional Pink Screen At Startup ) try to use an external Monitor. if it,s fine on an external. this will eliminate motherboard or graphics chip fault.
Mike @ compurepair.
Sep 05, 2009 | Acer Aspire 4520-5803 Laptop
How to solve Flickering problem of LCD
I have an Acer 5920G that's only 3 months old and it's screen started flickering. Updating or rolling back the graphics card driver made no difference. I then updated the Chipset driver from the Acer website. It hasn't flickered since!
The graphics info has to pass through the chipset so I assume the driver wasn't up to the job.
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Acer Aspire 3610 Notebook Logo
861 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
