Question about Reddy R60A Utility Heater
When plugged in the heater makes a noise like it may be trying to start but shuts off after about 5 sec. Heater has not run in several years
  • 232 Answers
If it were mine- and the heater has been inactive for several years, I'd check for a rat's nest inside. If clear, it's time for some serious troubleshooting. Remove the top cover. Is the fan turning?
Posted on Oct 06, 2009
My reddy heater 115 pro starts, but shuts off after about 5 seconds of running , i replaced the filters and nozzle about 2 years ago
Here is a service manual:
http://www.desaparts.com/service_manuals.html
If the flames actually starts but the unit shuts off after 5 seconds you need to check the pump cover on your heater to make sure you have no cracks in the rear cover.
This could be from low pump pressure but most often this problem is caused from a defective control board.
Oct 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater/fan issues
There is a safety switch which will shut the heater element off if the fan doesn't run. If the fan doesn't circulate air, the element would overheat and could possibly start a fire, so the switch will shut the element down. I'm not familiar with this heater, but I would check to make sure the fan is operating and also check for any filters that may be plugged and restricting air flow. If anything interferes with the air passing through the heater, the overheat switch will shut down the element. That's the best I can do from here. Good luck.
Feb 28, 2008 | Vacuums
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
All pro multi fuel
This may sound dumb, but is it full? i have a simupar one and if i start it out at 1/4 tank or ness it will not run long before it shuts off.
Dec 12, 2007 | All-Pro Forced Air Kerosene Space Heater...
Reddy R60A Utility Heater Logo
299 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
