Question about Sony KP-51HW40 51" Rear Projection Television
Screen gets red tint then tv turns off - Sony KP-51HW40 51" Rear Projection Television
  • 115 Answers
To correctly repair your tv all three CRT's (picture tubes) would need to be replaced as instructed by SONY service bulletins. Many years ago SONY wanted a better brighter picture and began making some CRT's differently and "better" . But saddley they did not do enough testing . After a few years they realised the mistake and they paid dearly for it. Unfortunatly enough time has passed that the $750.00 or more cost or repair can only come of the consumers pocket . They are good solid tv's when the CRT's get replaced with Panasonic picture tubes.
Sometimes screen control adjustments can be done to make the TV work for now but usually a flicker in color remains and it most likely wil get bad again
Hope this explains it for you.
Posted on Oct 14, 2009
I had the same problem with mine. After A LOT of research, I never found a good solution, except that strange things seem to happen when TVs get too hot. On my Sony, there is a solid panel behind the cloth-covered lower front panel. I removed the solid panel and drilled a series of holes in it to allow more air circulation around the projection tubes. This seems to have corrected the problem, at least for the time being.
Posted on Oct 08, 2009
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
The tv has red and blue tint screen?
What is your TV brand and model?
Ed
Aug 09, 2009 | Televison & Video
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Jan 22, 2009 | Televison & Video
Strong red tint and a blurry screen
This is a serviceman only job.  It isn't worth it.  The parts and labor are at least $500.
Sep 15, 2008 | RCA P46924 46" Rear Projection Television
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
