Question about Whirlpool GR448LXPQ Electric Kitchen Range
Are there directions on how to replace whirpool over door hinges?
  • 120 Answers
Open the door, check to see where hinges are attached, and unscrew as required. Buy new parts and replace. Very simple for the homeowner with no experience to do.
Posted on Oct 05, 2009
Tip
Replacing door or hinges on a Ford Dodge Chevy Truck w/o removing the fender...
If replacing the hinges on a truck you always have a pain of a time re aligning the door. Unbolt the door/hinge bolts directly on the inside of the door first (not behind the fenders). The use a pencil to mark the outer edges of the actual hinges for alingment. This will allow you to set the new hinges in the exact same place as the original ones. When they are on start the 4 door bolts and tighten the very top and very bottom hinge (check for alingment). If set tighten the last two bolts or adjust accordingly. This way yo only have to do minor adjustment on the rear of the door bolts versus all bolts and saved time by removing the fenders to adjust the hinge/body bolts..
on Dec 06, 2009 | Ford F-250 Cars & Trucks
What the easiest way to replace driver side door?
REMOVE EXISTING DOOR PANEL AND DISCONNECT WIRING AND EXIT THE HARNESS FROM THE DOOR. ONCE THAT IS DONE OUTLINE THE HINGE WITH A SHARPIE THAT IS ON THE MAIN BODY OF THE CAR. REMOVE THE DOOR HOLDER AND HINGE OR HINGES AND YOUR DONE
Apr 08, 2015 | Cars & Trucks
I've got a whirlpool refrigerator, with a door and a veggie tray at the bottom. It has a black panel at the top, which shows the temperature buttons. I want to change the door from opening to the left
oh your whirpool refrigerator has a door?
black panel? you mean a cover over the hinge mechanism?
if you cant figure that out, you need to CALL A PROFESSIONAL
Dec 29, 2014 | Whirlpool Refrigerators
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a whirpool side by side refridgerator and the door flap to the ice dispenser isn't closing.
Look up into the door area from the outside with a flashlight there is a good chance that a plastic tab that holds a metal hinge pin is broken. If so you need a kit to repair this problem.
Apr 15, 2011 | Whirlpool ED2FHEXM Side by Side...
Whirpool prima oven door will not go back on. Any ideas?
Hi. Get a helper. Then open the hinges about 1/4 of the way until they stay in that position. With the helper, lift the door, start it going down on each hinge equally and it should go back on. If it is hard to get it onto the hinges use some penetrating oil spray like WD-40.
Jun 16, 2010 | Ovens
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
My whirpool oven door dose not open
If it is a drop down door, then you will probably have to replace the oven door hinges, if it is a door that swings open, then it could be a broken door catch that needs to be replaced.
Please rate my solution.
Thanks.
Sep 13, 2009 | Whirlpool Ovens
Whirpool super capacity 465 range
you have to put it all the way in the slots.
open the hinges a little there may be a hole that you can put a nail in it to keep it in that position till you put the hinges in.
Sep 17, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool GR448LXPQ Electric Kitchen Range Logo
81 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
