Question about Sport & Outdoor - Others
Will not reel the line back in. Line was twisted and there are some knots behind the spinner head and the spool. How do I remove the spinnerhead assembly to clear/clean this out?
    Sergeant:
  • 302 Answers
There should be a knob on the front of the spool that unscrews to remove the spool. this is probably the drag adjustment too. hope this helps
Posted on Oct 06, 2009
I have the 1276sli abumatic spincast reel. The issue is when am reeling the line in there is bump in the handle always at bottom as i crank the line in under load.
Hey michael,
Sometime when you add line to a spincast reel, where you tie the knot and wind line onto the reel, it makes a bump in the spool, this "bump" in the spool sometimes hits inside the reel everytime it makes a rotation....
May 18, 2017 | Fishing
String only comes so far when you shoot has enough line no knots or anything seems like its getting caught on something
unreel the line and hold tension on it when reeling back onto spool some lines dig in worse than others .
Sep 07, 2015 | Zebco 808 Bowfishing Spincast Reel 808...
My mitchell gold series reel will not retrieve line the motion is but the line will not wind around the spool
wrong type of knot at the start perhaps . A small bit of tape usually will fix that .
May 23, 2015 | Fishing
How do you put line on a magda pro star reel
Mount your reel on your rod. Run the line from your filler spool thrthrough the bottom guide of your rod. Pass the line througo the line guide on your reel and tie your line to your reel using an arbor knot. Put a pencil or dowel rod through your filier spool and have someone hold light tension on the spool as you reel line onto your reel.
Aug 03, 2014 | Okuma Magda Pro Linecounter Magda Pro...
Proper installation of fishing line
it needs to go on the reels spool in the opposite direction to the way its on the lines spool ,this will take all the twists out of the line when its on the reels spool
Apr 07, 2012 | Sport & Outdoor - Others
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How in the bloody hell do I change this 'quick change spool' on my z03 omega? I can't seem to figure it out for the life of me...
Unscrew the front cone. While holding the handle unscrew the spinner head and remove from the reel. The quick change spool will have an arrow to show the direction that you twist it off. That's about all their is to it.
May 24, 2011 | Zebco Omega Spincast Reel
Starter rope on UST generator got behind wheel. Took cover off and spring unwound. Rewound spring inside starter rope wheel. Every time try to wind rope spool back inside cover and replace, inner spool...
Hi, W/D here.
Go at it from the other end. Take the handle off of the rope. If you have a fine piece of wire, attach it securely to the handle end of the rope; you'll use the wire to feed the rope back through in a moment. Wind the spring and starter wheel. When it's getting about as tight as you want it, align the knot hole with the shroud grommet. Feed the pull rope and wire through the knot hole, and out the shroud grommet, and pull the line all the way through, down to the knot. Catch the free end and put a slip knot in it, so it can't whizz on back into the reel. Attach the pull handle, and release the slip knot.
Best regards, W/D
Feb 13, 2011 | UST GG2300 Portable Gas Powered Generator
How do you put line in
Run your line through the guide and tie around spool using a good double loop knot
Oct 14, 2009 | Pinnacle Inertia Baitcast Reel
Sport & Outdoor - Others Logo
81 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
