Question about Nikon COOLPIX P3 Digital Camera
Black static hello,the screen shows up black with static when it turns on. i can view older photo's i've taken but can't take any new photo's. is there anyway i can fix it or will it have to go into a shop?
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
I just replied your previous question that this problem occurs due to ccd imager chip failure that will be replaced to get live view in camera mode to take fresh pictures.
Local camera repair shop will replace it, let me know if you need part number of ccd imager chip of DSC-T33 camera.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
D100 black image after photo is taken
Have you accidentally turned off "review"? You can also go to "reset" in the menu and try that.
Sep 17, 2009 | Nikon D100 Digital Camera
LCD screen black when photo being taken
Hi!
Have you tried pushing the button first under the mode dial? It changes view mode, just above the MENU button?
Tom
Aug 01, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I can view the images taken, but when I try to take an image the LCD screen does not show the image, screen is black
hey my camera just did the same thing, have you tried replacing the batteries - i thought it couldnt be the batteries because the playback screen still showeed up just not the one to take photos but i just put in newly recharged ones and it can take pics again so maybe try that :)
Apr 22, 2009 | Fuji Finepix S6500FD Digital Camera
Won't Take Photo
Hit buttons for the ISO settings on the photo you just took; if the settings are way off, maybe you can correct those or select a mode which gets you a proper image in the LCD; or reset the camera.
I for one wish I would jog the camera to a local shop for free adjustment (e.g. lens reattachment) the first time I ran into symptoms like that. I always let it fester 10 min, though.
May 10, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon COOLPIX P3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
