Question about Kenmore Elite 45986 Front Load Washer
Keep getting a f1 error
It seems that when the washer is trying to fill we get this f1 if you stop and restart it will finally wash. we did replace the water hoses and the water pressure increased alot but we still get the code
    Brigadier General:
  • 3,614 Answers
HI,
The F1 error code indicates a problem with the water level pressure transducer signal on the machine control board. This can be caused by a kinked or torn air pressure tube that runs from the bottom of the washer tub up to a connection on the machine control board (the water level pressure transducer is on the machine control board on this washer). It can also be caused by a defective machine control board.
Hope it helps
Posted on Oct 05, 2009
  • Brandy Nov 10, 2011
    I just called Whirlpool today 11/10/11 with the F1 issue. Whirlpool is contacting our local appliance store/repair place and arranging to pay them for the service call and work needed to repair the machine. In the meantime, the Whirlpool rep tells me the washer will most likely not be able to wash any more loads. With baby #6 coming in 5 weeks, this is a big concern! Hopefully the small town repair guys will come through for me.
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The F! error code keeps coming up when I start my washer
F1 means communication error, the best thing to do is unplug unit for 2 mins and try again
Jan 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
As soon as I put a load in and press start I get an f1 message. I proceed to stop and restart get the same message again restart it again and than finally it will begin wash cycle.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$%#@
Nov 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
