Back to:
Tags:
Magnum OmegaForce S45 CB Radio
Mic wiring
posted by lesboy10 on Dec 22, 2007
hi,
i have a deltaforce mic and would like to wire it to an omegaforce s45 magnum 6 pin plug,
the wire colours i have are-
pin1-white
2-black
3- red
4-blue
5-ground
6-brown
so now i need to wire it to the s45 which also has a 6 pin plug with up and down frequency buttons.
thanks in advance for ur help.
les
Comment by lesboy10, posted on Jan 11, 2008
sorry wont open bt thanks anyhow
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 10, 2008
Not Rated (0)
chiaflub67
Rank:Master Master
Rating: 86%, 13 votes
Check this link http://www.cbtricks.com/radios/rflimited/omegaforce_s45/index.htmand download the pdf file Owners manual page 8 has the info you need...Chia
Comment by chiaflub67, posted on Jan 11, 2008
go to www.cbtricks.com scroll down to radio info go to R undr RF limited youll find the info on them both....chia
according to magnum there are the same you should be able to use the mic on either with out modification!! But dont use an RCI 6 pin they are wired different and youll blow out the computer ....Chia
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on mic wiring:
I don't want to Accept this solution
Can you Help with these CB Radios problems?
CB Radios
trying to solder up a sadelta ech master mic to a uniden...
CB Radios
i had changed my car battery yesterday and car radio is...
no recive meter at plus 30 has trans. on up/low/am
Can anyone help me wire a sadelta echo master plus classic...
galaxy 2527 all works except no dead key wattage.
Loading problems.
Repair Service
Find CB Radio Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
