Question about Hotpoint Dryers
I have a hotpoint TDL11P tumble drier on which the front drum seal havd worn through, i replaced this but the replacementhas worn through after just 2 weeks use. there was no obvious reason for the original failiure which i put down to ware and tare through age. Any sugestions as to whatthe underlying cause might be would be appreciated.
  • Hotpoint Master
  • 7,482 Answers
You may need to take the dryer apart again...check the drum rollers, if they are worn they will put excessive pressure on the drum as it rotates against the seal causing this problem.
Good luck
I hope this helps
Posted on Oct 05, 2009
How do I replace the belt on my hotpoint futura tumble dryer?
I can't answer your question exactly but in my experience tumble drier belts are not particularly complicated to replace but the process is fairly time-consuming and involved as in order to slip the new belt over the drum an almost complete strip-down of the cabinet is needed.
It is a route-march of removing screws and plastic trim until something important falls off. The task then becomes rather more a thorough interior clean and a changing of felt bearings than merely replacing the belt. The belts last so long that by the time they need replacing the other things are also ready for attention.
Apr 29, 2016 | Hotpoint Dryers
Squeaky noise on tumble drier
this could be the bearings on your hotpoint
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Apr 23, 2014 | Hotpoint TDC32 Electric Dryer
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Oct 14, 2010 | Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
Removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
Dec 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint tumble drier TDL52S
you dont need to take the back off. to get inside, first remove the panel on the bottom of the front, that will allow you to remove the front panel and you will be able to get inside the dryer. as far as stretching the belt, i have never heard of that. there is a belt tensioner that holds the belt tight though. good luck!
Sep 24, 2008 | Hotpoint TDL15 Electric Dryer
Dryers Logo
54 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
