Question about Singer 8280 Mechanical Sewing Machine
Machine wont move
The machine works to thread the bobbin but will not move when put back to regular sewing the knob on the side barley turns and there is no thread on it at all. If it does work it goes really slow. Even when the peddle is down to the floor. then it slows and stops.
  • habdu Sep 23, 2008
    My Singer Prelude was working without any problems. Now, when I tried to use it, it is completely stuck.. the wheel won't move at all.. What should I do?
I had the same problem where my machine stopped working right in the middle of a project.  I called me dad and he walked me through the machine over the phone.  It boiled down to the machine needing to be oiled.  If you're brave enough you need to completely remove the plastic case and oil with sewing machine oil. Refer to manual for proper spots to oil or dish out the cash to have it professionally oiled.  If you do it yourself turn the machine by hand (small twists back and forth) until the machine loosens up and definitely until it turning smoothly.  Then put it back together and plug it in and give a try....should work.  Hope this helps.
Posted on Jan 06, 2009
I just found out that if you still have the bobbin winder on, the machine won't turn at all. So make sure that you have the winder slid over.
Posted on Nov 10, 2008
I tried the free style quilting on my Q10 and now it wont sew properly on the regular side. When I set it on a 4, or any number for that matter,the underneath is in tiny stitches. is there a proper se
make sure the thread is coming off the thread spool easily,, also make sure the top thread is pulling easy thru the tension disc,,
take the bobbin out of the bobbin case and put it back in the bobbin case--make sure the bobbin is turned counter clock-wise
keep working with the top thread tension,, also try some unwaxed dental floss on the tension disc if possible,, and the try setting the tension to 4 or 5 and see if that helps,,, but if you go thru all the top thread tension numbers and still the stitches don't change then you may have to have the machine checked
Dec 19, 2014 | Sewing Machines
My top thread is thick on the back side of the embroidery item. And top stitches have loops. Help
1. thread machine correctly.
2. make sure the bobbin is installed spinning the right way in the bobbin case.
3. put the tension knob back to middle (if this is possible numbered tension knob)
Jul 20, 2014 | Brother PE770 Computerized Sewing Machine
My Viking 950 won't sew or thread a bobbin, this has never happeed before, am I missing something?
There is a lever on the bobbin winder which needs to be shifted back or the knob for cranking the machine into position needs to be pushed or retracted back so it would engage the machine and not the bobbin winder.
Mar 12, 2014 | Platinum 950E Sewing Machine
Janome 134 sewing machine needle moves while in winding bobbin
sometimes that happens the wheel could be stripped and not tighten all the way it will not hurt your machine just make sure it is not threaded
Nov 30, 2013 | Janome Sewing Machines
Singer Prelude 8280 Sewing Machine stuck
Is the knob on the side, where you loosen the needle to rewind the bobbin, tightened? Also, there may be some threads in the bobbin case messing things up. Unplug the machine if you are checking the bobbin case.
Apr 18, 2013 | Singer 8280 Mechanical Sewing Machine
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
How to put thread on a bobbin of a Kenmore Sewing machine
I could not find a guide for this model.
If there is a knob in the center of the handwheel, it needs to be loosened.
Take the thread from the spool around the first guide and then to toward the bobbin winder.
Run the end of the thread through an opening in the side of the bobbin spool.
Hold onto about 5" of the thread and place the bobbin spool onto the bobbin pin and move the pin to the right or the winding wheel to the left (depends on how your machine is designed).
Holding onto the thread end, press the power pedal.
When you cannot hold onto the thread any longer, stop the machine and cut off the thread end and then continue to wind the bobbin.
Disengage the bobbin winder (move the pin or the wheel back into place) and tighten the knob in the center of the handwheel before sewing.
Mar 24, 2010 | Kenmore 12912
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
Jan 16, 2009 | Brother Sewing Machines
I can't find my manual and cn not get the bobbin to thread correctly
you need to insert the bobbin so that when the thread pulls off it spins counter clockwise. on the side closest to you there is a notch that you slip the thread into and then pull along the side towards the back of the machine staying on the left. once you've done that you can manually turn the knob on the side to make the needle cycle down so that the upper thread will pull up the bobbin thread.
Nov 25, 2007 | Singer 6038 Mechanical Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
202 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
