Question about Dishwashers
Model # HSD5011K00MB hotpoint dishwasher...the lights keep flashing and it appears to be on hold..please help
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
IFIXALL
  • 868 Answers
SOURCE: hotpoint sdw60 dishwasher the delicate light keeps flashing
Very sorry ,Control board  is bad ,listen even if you replace that you are going to have modify the whole d/w to make it right.Contact manufacturer and see how far this problem will go.
Posted on May 23, 2008
SOURCE: hotpoint dishwasher bf1620 - 1st
Posted on Jun 02, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Posted on Apr 08, 2010
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Manual for hsd5011k00mb
Hotpoint was purchased by GE -- What information are you looking for? They may be able to send you a manual if you give them a call. :)
Jun 16, 2014 | Hotpoint Dishwashers
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 | Dishwashers
Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Aug 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
NOT HEATING AND DELICATE LIGHT FLASHES
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Jun 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Fast and delicate lights flashing.
No, do not repair this, everyone who has purchased this model should demand a refund !!!!The problems are endless.
Apr 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
287 people viewed this question
Top Dishwashers Experts
