Question about Kenmore 62602 Electric Dryer
Kenmore dryer model 110
Quarter in the lint filter. How to remove it?
  • 32 Answers
Unplug you dryer or turn the power off. use a magnet along magnet if you have
Posted on Dec 23, 2007
  • Ralph  Stoker
    Ralph Stoker Dec 23, 2007
    if that will not work you will have to remove the back panel and remove the blower housing to get it out, also if it is not causing a problem don't worry about it.
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
I have a kenmore gas dryer 110 it doesnt dry the clothes the burner goes on then of stays worm not hot check the fuse its ok the igniter works also dont know what else to check
if the flame is liting but stops after 15 to 30 minutes you have bad gas coils.if the flame is liting and clothes are not drying you have to clean out the dryer and the vent line.remove the vent line,if it's a long run to the outside i use a leaf blower to blow out the line,check the outside and make sure nothing is blocking the vent like a screen or cage,if there is remove it and don't put it back after you blow out the line,then clean out the duct that the lint filter slides into,if filter is on top the duct is in the back,remove the front panel and vac out all the lint in the cabinet where the motor is.number one problem with dryers is lint build up,all a dryer does is move air,if it's clogged with lint your gonna have problems.send full model number next time and let me know how you make out,if you need more help let me know
Jan 22, 2011 | Kenmore 74602 Gas Dryer
Hello, i'va a kenmore gas drier model 75818,the problem is that it does not heat up at all, have checked the ignitor and momentarely glows but after loud clicking sound it turns off,any ideas?,thanks,ray.
next time send the full model number,starts with 110. or similar,i would change out the gas coils located on top of gas valve, do one at a time and look for a metal spacer that needs to stay on post,sometime it slides off when you remove the coil,only on one of the coils,also if you haven't cleaned out the dryer it would be a good idea to do so, unplug dryer,if lint filter is on top remove the filter and the two screws in front of filter,remove the vent line if it's a long run blow it out with a leaf blower or shop vac but leaf blower works better,take off back wall and take out the four screws that hold the duct in that the filter slides into,clean out the duct,put it back together except for the two screws on top,now pop the top and remove the front panel and vac out the inside,if you have a shop vac blow out the dryer motor and all,if filter is inside remove the bottom panel take out the lint filter and remove the duct the filter slides into and clean it out,if you have a shop vac blow the lint from the back to the front so you don't have to pull the drum,blow out the vent line,you should do this once a year you have an open flame in there and you don't need a fire,your dryer will run better and last longer
Jan 31, 2010 | Kenmore 73932 Gas Dryer
Battery fell in lint area of kenmore dryer.
next time send model number,open the door,look around the opening where you put the clothes in and you'll see the number,might start with 110,is the filter on top of dryer?if so unplug the dryer,take out the filter and remove the 2 screws on top where you pulled the filter out of.now go the back of dryer,take off the vent line and remove all the 1/4 inch screws in the back panel,on the left side you'll see a metal duct that the filter slides down into,take off the 4 screws most of the time they're 5/16 inch screws,remove the duct or slide it to the right and you'll see the blower wheel,you should find the battery there or in the bottom of the duct,vac that duct out while you have it off and clean out the vent line,if the filter is inside take off the bottom panel,you'll see the duct in the middle,take out the filter and remove the screws and you'll see the battery,good luck
Jan 22, 2010 | Kenmore 63012 Electric Dryer
How do I change the drive belt?
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
Model number 110-85866-400. Will not turn on
unplug dryer,you have to take bottom panel off,take out lint filter and then remove the duct that that lint filter goes into,you'll see it on left side when you remove the bottom panel,if it died you could have blown the thermal fuse part number 3392519,you will find this on the right top side of the blower wheel housing it's white and has two wires going to it,pull one wire off and check it with a meter,also go outside and check the flapper were it vents outside,that could be blocked,i blow the vent line out with a leaf blower if it's a long run.if you're having lint problems that should take care of it,also if you have a shop vac,put it on blow and blow off the motor,and you can blow all the dust that' in the back forward so you don't have to remove the drum.hope this helps
Nov 09, 2009 | Kenmore Elite HE4 Electric Dryer
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
HE4 Kenmore Elite Dryer error code 4e
If you have ever removed the lint filter area completely via the screws that hold the plastics in so you could clean it then remove it again and insure that you plugged in the two wires that go to the strip sensor.. (moisture sensor)
May 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
