Question about Dryers
Need a schematic for model 110.76732500 gas dryer and how to open the unit and replace the motor.
  • Dryers Master
  • 7,482 Answers
Try this website:
http://laundry.manualsonline.com/manuals/device/clothes_dryer.html?
or this one:
http://www.partselect.com/
Good luck,
I hope this helps
Posted on Oct 05, 2009
  • 1,000 Answers
Go to www.searspartsdirect.com , enter your model # and you will get a good parts schematic for your dryer.
Where can I get the schematic for my Kenmore dryer 110.73952101
the schematics sheet is under the head unit of the dryer where the timer is. In some dryers, the ones with the bottom front tray, you can find it in an envelope along side the wall of the dryer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jul 06, 2014 | Kenmore 63942 Dryer
Mdg9700 drum not turning
Without the schematic all I can do is go by the general schematic the schematic should be located in the control panel anyway a broken belt will cause the tumbler not to rotate, a bad belt switch, probably not the problem, an open safety thermostat will stop power to the motor, a bad motor of course will cause the problem and lastly a bad relay on the control board will do it, remember I do this everyday so for a DIY it make pose a bit of a problem to know these part locations or how to disassemble the unit
Mar 23, 2014 | Maytag Neptune MDG9700A Gas Dryer
How to know if motor is bad
I am a WP tech need exact model number dont change many motors does the unit power up and when you push start do you hear a click if so probably an open fuse again model # will show you how to place in diagnostic
Mar 22, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer won't start - only beeps
If this unit has a timer it could be faulty. Make sure with the schematic in hand that all the wires are in the right spots on the motor. I did not post the model number so I am not sure what model you have but looks like a Whirlpool part number. If motor was running before you attempted to remove blade, this is a good one. If the motor relay is clicking but not turning that is almost like power is not were it should be. You can contact me here or reply to FIXYA with a response. Click here http://apcoappliancerepair.wordpress.com/?s=dryer+motor to see posts on dryers. I wish I could be more help. The first place I would start is with a schematic.
Apr 30, 2013 | Dryers
My dryer no longer heats
Small Diagnostics: is the gas line open, does the dryer still operate (tumble) but it does not heat, does the exhaust blow air out if so then the gas delivery, motor, vacuum motor are possibly working properly.
website http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170716&diagram_id=28476104#d28476104
Issues might then be in the ducting or the heating unit, this is the schematic of the gas line, heating, and ducting within the core of the dryer: If you take a close look at number 16 which can be seen inside the tumbler, Sometimes the port/ matrix of small air vent can clog up due to lint. Make sure that vent is not blocked. This prevent hot air from coming into tumbler.
When a unit over heats or fails it could be related to the high limit thermostat which is a sensor that get tripped or blows when it reached its limit check and see if its fried/ burnt (number 17).
Diagram number 2: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170716&diagram_id=28476105#d28476105
This one contains or blown out thermostat fuses check and see if they are OK on diagram 2, Part number 8 Tstat and 10 thermal fuse.
Hopefully this help.
Jan 10, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer doesn't "dry"... eletrician/husband inspected the unit- circuits working for heating element. Belt intact. Dryer tumbles, but doesn't get HOT. Thermostat?
It depends on if the unit is electric or gas. Both will have a thermal fuse if the venting is restricted the fuse will blow if its a whirlpool or kenmore brand. The thermal fuse is white and will be either located on the back or in the front by the blower housing. If the lint screen is located in the top the fuse will be in the back. Have your husband take a look at the schematic he should be able to find the fuse. Also i know he probalby checked this but the unit needs 240v for the unit to heat if its electric but the motor will still run with 120v. Make and model would allow me to help much more.
Jan 11, 2010 | Estate TEDS840JQ Electric Dryer
My dryer wont heat up. Where could I start, and do you know where I can find a schematic?
model and manufacturer would help
but i would check your element if electric
and ignitor if gas
go to www.appliancepartspros.com
type in your model number
they usually carry most schematics and parts break downs
hope this helps
Oct 25, 2009 | Kenmore 74652 Gas Dryer
DRYER NOT WORKING. MODEL #LGR7646JQ0, SER #MK4629649, PURCHASED 11/18/00. PROBLEM: DRYER COMES ON HOT AND QUICKLY (ABOUT 5 MINUTES TURNS COLD) IF I WAIT ABOUT 2 HOURS AND TURN IT BACK ON IT REPEATS HOT...
http://www.searspartsdirect.com/partsdirect/retrieveModelAction!retrieve.action?modelNumber=LGR7646JQ0
This should show you a parts break down for the unit. You can also find a schematic in the console (usually about 6 1/4" screws from the back of the console). As far as your problem, overheating could be causing it. Run the unit without the vent attached and see if the problem persists. If the unit keeps running, you'll know you have a venting problem. If the problem persists, I would usually replace the gas valves (usually one goes bad and won't hold open). These would be availible from a local appliance parts store.
Jul 08, 2008 | Whirlpool Dryers
Wiring diagrame for hotpoint gas dryer
E-Mail me and I will send you a copy of my Schematic. It's 2 pics, but they are pretty clear and should help you. I came to the site wher I saw your post looking for a pic of an exploded view of our dryer. Trying to open it to fix the glide bushing. Started makin metal to metal noises lately, so I am assuming it's like a nylon glider for the drum?
SyxPakk@Yahoo.Com
Mike.
Feb 19, 2008 | Hotpoint NVL333GY Gas Dryer
Dryers Logo
201 people viewed this question
Top Dryers Experts
