Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Can i replace the hidden speakers in a samsung LCD tv? It seems like the internal subwoofer is not working properly since deep bass sounds have quite a bit of static. Perhaps it is only due to the lower quality of the speakers?
  • 5 Answers
SOURCE: samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Posted on Dec 31, 2008
  • 304 Answers
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
SOURCE: No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Posted on Dec 01, 2009
  • 1768 Answers
SOURCE: Samsung LCD TV SRS trusorrund.... Sound Problem.
1. You could have a bad cable on the amplifier for that channel
2. the processor in the feeding that channel may be malfunctioning.
I am not familiar with this unit but all surround have the same basic principal to separate and compress sound to give the 3d illusion of realism. All this is processed at the central unit in the amplifier.
3. Your unit may need service at the component level or replacement of the main board is needed.
4. You also may have a problem at the gaming console * not sure if you are using a PC OR PS3 unit or Xbox.
I hope this helps.
Posted on Jan 23, 2010
Testimonial: "Thanks :] Im using xbox360 on my TV. and RocketFish HDMI cable.. It only happened when I tried to vacuum (Minimal Level) the wholes near the speakers."
  • 304 Answers
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Posted on Apr 16, 2010
How to build a box for my 2 Lanzar Max 12d subs to get real deep low bass
If you have a spec sheet as far as volume and any trunk dimensions I can design exactly what you are seeking.
Jul 21, 2012 | Lanzar MAX12D Car Subwoofer
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
I have a brand new LG 37" television. Picture quality is perfect but the in-built speakers vibrate heavily to a deep bass sound. I played "Close Encounters of the 3rd Kind" through the dvd player and in...
i also have this tv.same problem too.i bought two multimedia bose speakers for 100$. they are actually designed for a laptop but trust me....they are better than most so called surround sound speakers designed for tv's.these tv's are not known for their built in speakers.
Aug 17, 2010 | LG 37LG50 37 in. LCD HDTV
Subwoofer stopped
the subwoofer only works when deep bass signals are sent to it.you may not have had any in the music/movie you were watching..check yr on screen menu for settings
Jul 08, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
My 15 & 10
On a 10 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 20 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. Or 275mm high, x 275mm wide, x 275mm deep. Seal the boxes with silicone for better bass
Oct 21, 2009 | Hollywood Sound Lab Hollywood Digital...
MB quart DTE-169seems like the bass is not functioning properly.
What exact problem is with the bass. Does it sound funny or is there not enough of it.
Jun 08, 2009 | Car Audio & Video
Bass not Very deep
250 watts rms seems a little low for a 12 inch woofer, a 500 or higher will likely fix your problem. Specific model numbers and the type of enclosure you have will allow a more specific answer.
Mar 17, 2009 | Car Audio & Video
Bought Logitech z-cinema 2.1 but the subwoofer does not seem to work properly...
The subwoofer features Logitech's eight inch long-throw sub in a bass-reflex enclosure. The sub is capable of throwing out 110W RMS with frequencies down to 35 HZ to give you that deep bass for the earthshaking explosions.You must have problem in the product .the installation might have been not proper ... check it via a sound engineer
Oct 02, 2008 | Computers & Internet
Jl 12's w3 not all types of basses sound right
zzedly only asked only one good question, here is what should've been asked.
What size is the enclosure?
Sealed or ported?
What frequency is it tuned to if ported?
How much power are you running?
and
What frequency is your LP crossover set to?
Mar 14, 2008 | Jl Audio 12W3 Car Subwoofer
Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Jan 05, 2007 | Sony XS-L1200B Car Subwoofer
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
318 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
