Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
My Kitchenaid dishwasher seems to be stuck on the wash cycle for over an hour. How to I fix this?
  • 120 Answers
Check to see if you don't have it on an extended wash cycle setting. After that, check to see if the dial is stuck.
Posted on Oct 05, 2009
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
Kitchenaid dishwasher stuck on wash cycle
I'd you wish to get some details then check the following link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | KitchenAid Dishwashers
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
KITCHENAID DISHWASHER STUCK IN WASH CYCLE
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jan 16, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid Superba dishwasher getting louder in wash cycle
The bearings in the wash motor can wear and cause the machine to get louder, They can be replaced but it depends on the age of the machine if it's worth repairing or not.
Mar 08, 2012 | KitchenAid Dishwashers
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
The wash cycles go on for 2 - 4 hours.
I know is sounds strange, but on a typical Kitchen Aid dishwasher, cycles can go longer because the the dishwasher is waiting for the water be raised to the proper temperature, especially during a hot rinse cycle.
Checking that the heating element is working would be the first thing to check.
If the heating element is working, the probable cause is a failed console (which controls the logic/programming of the dishwasher.)
Good Luck!
Apr 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Aug 05, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
392 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
