Question about Acer TravelMate 2423NWXCi Notebook
MY TRAVEL MATE 2423NWXCI 2 YEARS OLD GETS OVERHEATED AND HANGS IN HALF HOUR THEN I HAVE TO LIFT IT UP SO THAT AIR CAN FLOW TO THE PROCESSOR WHAT TO DO I USE XP 2
  • 154 Answers
If the heat sink air vents are on the underneath of the laptop, they must be kept clear at all times when the laptop is in use. Try using the machine on a hard tray, table or some other type of surface that keeps the vents clear. Sometimes, if you want to use the laptop on your knee, judicious positioning of it to keep the vents clear will sort the problem. If the laptop overheats when used in this manner, switch the laptop off, and try a vacuum cleaner with attachment to clear the debris from the heat sink via the vent holes. DON'T leave the vacuum nozzle on the vent too long, or get it too near the vents otherwise you may damage the fan bearings. Just be careful, and this can often solve the problem. If it's easy to dismantle the underneath to get at the vents this is preferable, but travelmates are notoriously awkward to do this to. Hope this helps. Kind regards
Posted on Oct 05, 2009
How can I get my DC26 working?!
They can cut out due to overheating. Although you say you have 'cleared' the filters, they should ideally be washed as they can clog with very fine dust and cause overheating due to lack of air flow. Once a machine cuts out due to overheating it can take maybe half an hour (or longer) to cool down enough to work again.
Aug 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Acer Travel mate 7730 os xp laptop shuts down
make sure processor fan is working fine. you may hear the sound of fan on the left side of the laptop. and make sure its not getting heat soon. If the fan is not working you need to replace the fan. If if gets heat soon that means you have to put processor cooling paste.IF the fan is working fine and the processor heat is normal, then you need to re-fix the RAM. Then it will work fine..ok
Jan 26, 2010 | Acer Aspire 3100 Notebook
Fan Exagerated Noise
The noisy fan is most likely caused by a worn/faulty bearing. This causes the fan to vibrate in the bearing and spin slower and therefore cause overheating CPU problems.
The CPU fan needs to be replaced.
Sep 08, 2009 | HP Pavilion a705w PC Desktop
Rear projection set keeps turning off after it warms up
Sounds like thermal overheating. Is the TV in a "cabinet". If so...overheating is likely, Also...if the set is more than a few years old, you should clean all fans and filters (front, side, back) as approprite. Check the lamp and cooling fan...is it dirty? If so...cleaning is needed as inadequate air flow is most likely the culprit.
Jun 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Travel pal will not charge
It is time to replace the batteries. Buy two, not just one. This scooter takes two 12 volt, 12 amp hour, sealed deep cycle batteries. If you replace just one, the charger will not charge them properly. Take off the seat (pull upward). Turn the scooter on its side. Remove the six screws (2 in front, 2 under the foot rest, and 2 in the back. Unsnap the old batteries (one at a time) and replace with new. Be sure to keep the wiring as is, so you keep the circuit in series (not in parellel). In fact, before you remove the old batteries, label the connections (A to A, B to B, etc.) so you reconnect just as they were. Total cost is about $200. Time to replace is about a half hour.
Apr 01, 2009 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Monitor freezing and screen crackling.
Sounds to me like your graphics processor is overheating, or possibly the cpu. Are any of these components new? you may want to make sure that they have proper cooling. On the other hand if its a few years old, may jus need to replace the overheating component.
Mar 15, 2009 | Acer Aspire M1640 Refurbished Intel...
Toshiba Laptop overheating
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
Jul 17, 2008 | Toshiba Computers & Internet
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
!!! TOSHIBA SHUT DOWN !!!!!!!
If ventilating helps, check that the vents on the bottom and where the fan blows out warn air are'nt blocked, try gently hoovering around area witha nozzle.
Oct 21, 2006 | Toshiba Satellite A60 Notebook
Acer TravelMate 2423NWXCi Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
