Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Garbage Disposal. Operates but water does not empty and shoots up into sink.
  • Johnny
    Johnny May 11, 2010
    dual sink? if so are both sinks flooding?
Took the trap off and emptied debre in it . Works fine now. Thanks for checking. Ed Bachleda
Posted on Oct 06, 2009
My garbage disposal is not working. it "hums", but doesn't grind, and water drains slowly. there is nothing stuck in it.
You are going to have to try to push it through the stuck point. It is clogged without a doubt. Could be a piece of silverware in there. Use a flashlight and take a look down in the hole. Do not stick your hand in there but you can use a pliers or something to dislodge it.
May 16, 2016 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Insinkerator 100ss sounds like it is running but does not empty the food completely out, thus causing stink! Please help.
run water while unit is on
add ice cubes with water running and unit on
until all food particles are gone
ice and lemon for a pleasant sent
Sep 15, 2012 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Water leaking on bottom of disposal by wire connection
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 09, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal doesn't empty
To me it sounds like the waste pipe is clogged
Try a plunger
Kurt
Mar 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
97 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
