Question about Whirlpool Dryers
Drye runs but does not get warm - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
Sounds like your heating coil is faulty.
Unplug the dryer, remove the back of the dryer.
Locate the air tube going from the blower to the drum.
Normally inside the air tube is where you will find the heating coil and thermostats.
Remove the wires from the heating coil...and check with a continuity meter across the two terminals...you should read continuity across the terminals, if you do not read continuity across the terminals then the heater coil is faulty.
Good luck,
I hope this helps
Posted on Oct 05, 2009
Damp clothes when done
Your problem is going to be 1 of 2 things either the dryer is not tumbling o you're not getting adequate air flo out of the drye which basically suffocates the drye which basically suffocates the dryer element preventing it from drying, you can check this by turning the dryer on and finding out where the vent is outside and verify airflow is good. My guess would be the second is the problem
Sep 07, 2012 | Kenmore Dryers
My duet drye will not get hot but runs
check your heating element if gas test regulator
Aug 25, 2012 | Whirlpool Duet WFW9550 Front Load Washer...
Maytag Neptune MGD9700A The heater was getting warm but not drying hot. I replaced the coils (servos) first. This did not solve the issue. Then I replaced the Thermistor, the thermostat and a second...
remove venting from back of dryer and run a test load with clothes if it dryes clothes with venting off then its a venting problem.....remove from back of dryer
Jan 31, 2011 | Dryers
2006 CRV instrument panel ghosts.
Sounds strange,look in your manual this may be a warning code if it bounces to the same rpm range. if not check your ecu black box ,if water or damp getting inside it may be causing the problem untill the engine heat dryes it out.
Mar 02, 2010 | 2006 Honda CR-V
My Kenmore drye 97511100 runs but has no heat
the heat elent is damaged or the thermostat don't work, in the good case you have a broken wire or disconected.
Feb 15, 2010 | Dryers
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
INK PEN LEFT IN DYERS NOW INK MARKS ALL IN DRYER
try some OOPS Just make sure before you run drye again, you have wiped out inside because OOPS s flammable.
Sep 12, 2009 | Whirlpool LER4634J Electric Dryer
What does it mean if my roper dryer runs but doesnt get hot ?
either the breaker has tripped and not allowing it to heat,thermal fuse kit may have gone bad or element is bad.that is normal problems with dryers.first check to see if 220 is going to dryer and drye cord is in good shape.no burns.
Mar 10, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont dry but heats and tumbles. takes 3 cycles to dry
Have you checked the entire duct run. When dryer vents should feel like a hair dryer on high blowing outside
Feb 16, 2009 | Roper RES7646KQ Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
