Question about Tasco Waterproof Offshore Binoculars
Tasco 7x50 322BCW The battery for the compass light is missing and we do not know which battery is the correct replacement. Can you agnesrp@verizon.net
I need a new compass for tasco 322 BCW waterproof binoculars. Any ideas where I can find one?
Open the battery door, clean all inside with Alcohol & Q-tip. Check that the AG10 or 389 batteries are positive up. Now the compass dial pivots on a shaft. It seems to get caught. Take a strong magnet and rotate it above the compass lying horizontal and spin it until it spins freely. Take it away slowly. Does the compass settle down to accurate heading? If so place back in the top of the model 322BCW observing the glued in marks on the clear window area. Re-screw in, press brass button red LED should light.. If NOT recheck for corrosion. Regards, Don
Jul 03, 2012 | Tasco Optics
INEED A MANUAL FOR TASCO OFFSHORE BINOCULAR OS36 7X50 RANGE FINDER COMPASS
http://mrcirl.org/whale/Binocularsmanual.pdf, little late, this might help someone out there......
Jun 16, 2012 | Tasco Offshore Binocular Os36 7x50 Range...
Hi, We're looking for a power supply for a Tasco Starguide 80. Not sure what voltage etc it needs. Any help much appreciated!
12 volts-- a car starter battery with the correct 12 volt cigarette light style plug will work just fine. Contact TASCO for the correct power cord--
http://www.tasco.com/pages/repair-and-warranty/
May 03, 2011 | Tasco Starguide Computerized 80mm...
New bateri
What batteries are needed for OffShore 54 tasco binoculars?
Mar 20, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
Need owners manual for Tasco 14F and also missing attachment at the end of the scope that holds the... lenses? (the part that you look through) Sorry, don't know the name for this part. This is my first...
All of Tasco,s manuals are on this web site
http://www.tasco.com/pages/instruction-manuals/
and customer service here
Oct 27, 2010 | Tasco Galaxsee 46060675 (675 x 60mm)...
Tasco luminova
A manual will not help you-- just go to any well stocked hardware store and buy replacement nuts and bolts, in stainless steel. Tasco will not sell you these parts.
Apr 30, 2009 | Tasco Luminova 40076420 (420 x 76mm)...
Binocular tasco os54 with a stock compass possible due to broken bubble inside
this can be obtained by calling bushnell customer service at 1-800-423-3537.
Oct 27, 2008 | Tasco Sonoma Binoculars
Tasco OS36 Binoculars battery replacement
The screw you removed holds the battery cover in place. The cover is roughly rectangular with rounded corners. Once the screw is out, gently insert a sharp blade into the hairline crack between the cover and the binocular body and pry the cover off. The two watch batteries will be obvious.
Dec 03, 2007 | Nikon Travelite V Binoculars
Tasco Waterproof Offshore Binoculars Logo
501 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
