Question about Maytag Dishwashers
I have a Maytag MDB-6 dishwasher. The water will not enter the dishwasher when I turn on the wash cycle but it will when I put it on the rinse cycle. How do I fix this?
  • 120 Answers
You need a new timer mechanism. Purchase replace as required.
Posted on Oct 05, 2009
How much water does a dishwasher use per cycle
auto clean 4 to 10 gal
heavy wash 10 gal
normal wash 4 to 8 gal
light wash 4 to 6 gal
rinse only 2 gal
Jun 14, 2014 | Maytag MDB7100AWB Dishwasher
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
My dishes come out dirtier looking after washing in the machine.
check the water temperature is reach the desired setting,clean the rinse arm and check the rinse soaf if working at end of wash cycle.
Jun 05, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Maytag DWU8330AAX: glasses, plates, utensils,
The rinse cycle is the same as the wash except the wash uses detergent and the rinse uses rinse aid.
The rinse cycle will dispense rinse aid if you have filled the dispenser. Check this first, that would be the most likely cause. Also in the spring as the water table table in most cities begins to rise the water quality goes down, extra calcium in the water can cause this problem.
Here is a link to help understand that. Let me know if you have questions.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 02, 2010 | Dishwashers
Maytag MDB7100AWB dishwasher. 'High Current' during wash cycle. What do I need to do? Thanks
What problem is the "high current' you mention causing?
Many dishwashers continue to heat the water to a higher temperature to wash and rinse the dishes with. They turn the heat strip on to do this, which causes the dishwasher to pull more current.
Dec 16, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
170 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
