Question about Kodak EasyShare DX6340 Zoom Digital Camera
All of a sudden the camera will no longer charge on my Kodak Easy Share dock although the battery is fairly new
Ammumama that was the dumbest thing to post. We're trying t o find the problem, not a new camera.
Posted on Dec 28, 2009
  • ShadeyLane Dec 28, 2009
    ammumama, that was the dumbest answer to post. We're trying to find a solution, not looking for a new camera.
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Jan 12, 2014 | Kodak EasyShare DX7590 Digital Camera
My Kodak easy share is 5 yrs old. can I charge it without the printer dock as I want to take it overseas?
Depending on which camera model you have, you can use regular (lithium!) AA batteries in these cameras, no need to buy the specialty 2-battery rechargeable pack and use the printer dock to charge. You can go with regular NiMH rechargeable batteries as well.
Mar 10, 2011 | Kodak Cameras
My Kodak Easy Share DX6490 will not turn on. When I place it on the charging dock, the lights flash like it is transferring photos to my computer and the flashing won't stop even if I remove the camera...
Hello, sounds like you have a faulty battery,if the battery is several years old it will lose the capacity to boot the camera and the dock is trying to charge a defective battery,if you get a new battery, charge it for at least 6 hours or more.Hope this solves your problem.
Regards,Russell
Aug 16, 2010 | Kodak EasyShare DX6490 Digital Camera
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
With my camera on the dock and the dock light is on, the battery light does not come on at all.The camera is turned off. It does not show to be charging or to be charged. No light at all. Nearly new...
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Feb 19, 2009 | Kodak Z8612 Digital Camera
My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Jan 25, 2009 | Kodak EasyShare DX4530 Digital Camera
Kodak easy share c 340
try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Oct 23, 2008 | Kodak EasyShare C340 Digital Camera
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Won't hold a charge
what rechargeable batteries are you using and what's your method of charging?
If your using a dock for charging - make sure you have the battery pack kodak kaa2hr otherwise the dock won't charge it
if you're using a separate charger - it's ok to use other AA ni-mh
please check the age of your batteries as well.. batts, even rechargeable eventually wear out - they can last up to 300 charging cycles and a year or a little more than that is enough for you consider buying a new set
if you say that you barely use the cam, batteries still deteriorate through time
Apr 12, 2008 | Kodak EasyShare CX7525 Digital Camera
Docking and charging digital camera
Not sure if this will help, but you might try removing the batteries from camera, then see if it responds on the dock, if so it is most likely bad battery. That battery should be easy enough to find at locally. You might wanna try the Interactive Troubleshooter on Kodak's site. http://www.kodak.com/global/en/service/products/ekn030483.jhtml?pq-path=6861
Jul 28, 2007 | Kodak Dock Plus Bluetooth Thermal Printer
Kodak EasyShare DX6340 Zoom Digital Camera Logo
118 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
