Question about GE WSXH208A Front Load Washer
Smells like sewer when washing clothes - GE WSXH208A Front Load Washer
  • 34 Answers
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned. After the washer has been cleaned your washing habits must change to eliminate what is causing the smell. Go to www.smellywasher.com and fill out the "washing machine help" questionaire to get sent advice on what to change to remove the odor and to keep it away.
Posted on Oct 11, 2009
  • 403 Answers
OK, lets see what we can do to resolve this for you. Here is a link so you'll have a PDF manual for your item. Just copy and paste into your browser.
http://genet.geappliances.com/DocSearch/pdf/49-90025.PDF
Because you have a front loader water tends to stand near the door. Check to see if you have any standing water anywhere. When water sits it begins to smell. Clean out the entire inside of the washer with a product like Washer Magic. Do this before your next load.
Do this before you try anything. Get yourself a 5gal bucket as you should be able to move this without hurting yourself or throwing your back out. Look at the lines in the back coming out of the turnoff valves and to your washer. Are they rusted, if not proceed further. Turn off the lines and disconnect from washer. Don't get them mixed up so just do one at a time. Make note which is hot and which is cold. Place line into bucket and turn on water.
Be careful when turning on the water as there will be pressure and you don't want to lose the line so make sure someone is holding it inside the bucket . Do this for both lines. Fill up the bucket several times each time looking at the color, smell, particles coming out of the line, anything that is not normal. Smell each bucket and see how many buckets it takes before the smell is gone. In some cases it may take up to 3 or 4. Now after you have done this with both lines connect back to washer. You the washer magic or use 1cup of bleach and 1cup of white vinegar and do a load with no clothes.
You should be able to notice a great difference after following these steps. With the steps above if you are still getting that smell with each bucket of water you fill you have a issue with your water coming into your house. Are you using a septic tank, well, leach field. Let me know how this works for you and if I can help you with anything else.
JimmyC
Posted on Oct 05, 2009
Master_Tech
  • 770 Answers
SOURCE: sewer smell comes from the
you can flush the machine by running a full load with hot water and 1 cup of bleach should take away the smell
Posted on Jul 30, 2008
57 varieties
  • 1653 Answers
SOURCE: sewer gas smell
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
SOURCE: Internal Smell
I had the same problem especially in the summer time when the heat and humidity are high. ( I live in the south) The solution I have come up with is to keep the space between the wide rubber piece and the hard plastic piece that encircle the opening cleaned. It can be a pain to do because I am always afraid I am going to damage the rubber piece. I use a 1 - 12 solution of clorox and water and a soft cloth and a soft toothbrush for the ridged places. I also leave the detergent dispenser tray open when I am not using the washer so it can dry out. This has really helped me.
There is also a product that I have seen that is made just for this purpose. I saw it at Home Depot one day. It is probably available in the detergent aisle at other stores too, I just have not looked for it. I refuse to buy a product that is made to correct a defect in design. My clorox and water treatment works just fine for me and is much less expensive.
Posted on Nov 14, 2008
  • 523 Answers
SOURCE: Kenmore Calypso washing machine has an odor during washing cycle
clean the washer with bleach and a small amount of detergent
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: my washer has a sewer
smell is probably caused by mould growing in the machine. some possible fixes:
- dry the machine out between wash loads. wipe the door gasket and door, leave the door open, etc. - avoid using liquid fabric softener in the wash. it may or may not be a factor, but it's one less thing to worry about. - run baking soda or chlorine bleach (or any other fungicide, like tsp) through the machine on the hottest cycle available ("sanitize" if your model has it). if using bleach (or anything else that doesn't belong on your clothes), run an extra cycle to rinse out the bleach before putting clothes in. - clean the pump filter. there's a little nylon widget, near the bottom of the machine, that collects lint (and other debris, such as socks, coins, etc.) that needs periodic cleaning. the stuff caught in there can grow mould. no, your user manual doesn't mention it - why do you ask?
Posted on May 09, 2011
We purchased a kenmore high efficiency washing machine. after the second load, we get a sewer smell in the other part of the house.do you have any suggestions?
There may be a venting problem with the sewer lines. These machines expel water very fast and at higher pressures than other types of machines. This can cause suctioning of water from drain traps if there is improper or clogged venting of the sewer lines. Have the sewer lines checked by someone knowledgeable about proper venting practices.
Aug 23, 2014 | Washing Machines
Sewer smell in clothes
The tub is probably pretty dirty. Try cleaning the washer with CLR.
Visit this information:
http://www.ehow.com/info_8053120_clr-clean-washing-machines.html
Mar 19, 2014 | Fisher and Paykel GWL11 Top Load Washer
Washing machine sewer odor
The drain pipe that your drain hose goes into is more than likely the problem. The drain pipes should have a p trap which looks kind of like an S- shape the water stays in the trap preventing the smell from backing into your home . If there is none, install one.
Jun 09, 2013 | Washing Machines
I have a whirlpool cabrio washing machine.ecerything is working fine but its beginning to smell like sewer. The sink next to it doesn't smell nor the drains. It's coming from the washer. Anything I ca
Clear your filter.
Remove detergent drawer and clean the drawer and its receptacle on the machice.
Bung in 8 milton tablets in the drum and put it on the hottest longest wash you can and leave it run normally.
Run a short cold wash to flush the machine
Now put some nice smelling low foaming disinfectant in and repeat the hot wash cycle.
This should sort it but may take repeated treatments. Lower the amount of softener and detergent you use as excess can build up and can cause this problem to come back. Additionally dont overload with really dirty cloths and if you do a wash with exceptionally dirty cloths then after you empty your machine put it on a shortest rinse cycle to purge and contaminated water that is left behind.
If all this fails you will need to have your machine serviced.
Oct 03, 2012 | Washing Machines
Odor coming from washing machine - smells like sewer gas
The odor coming from your washing could indicate a problem with your
hot water heater or possibly your city's cold water supply line.
In some cases the odor might be originating from the drain located adjacent to
the washing machine. During long periods of inactivity, if no water is flushed
down the drain, a sewer smell will be emitted from the drain. To alleviate
this condition, just flush water down the drain.
I hope this helps you solve your problem.
Jan 17, 2011 | GE Washing Machines
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Apr 20, 2010 | Washing Machines
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
2,574 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
