Theres alot of possible reason why you're having those print out. In your case since your complaining about the ink being to wet.. check the paper that ur using is it a photo paper? is it inkjet compatible? did you use the same paper you used before? Possible that your Print Head is defective. Have you tried using the ITG(interavtice troubleshooting Guide) www.kodak.com/go/itg
If that does not work call kodak. 1-800-421-6699. :-P
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
Why don't you try going to www.kodak.com/go/5100downloads , and there download the Firmware (which is what actually allows your printer to work). It should fix that problem.
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call 1-800-421-6699.
Try to get the scanner operating by using a programme such as paint (open file from scanner or camera) or powerpoint (insert picture from scanner or camera). I have used this with success in the past. I have not used the scan button so I cannot advise you on this.
Hope this at least gets you going with scanning a copy of something and once you have it in these programmes you can at least print it and make some changes that you desire.
Hope this helps.
Youre right - they are a great printer!!
Johnca51
what exactly are you doing?
