Question about JVC GR-SXM265 S-VHS-C Analog Camcorder
Getting e01 message what to do
Getting error message 01 unit in safe guard mode remove and reattach battery but when i do that nothing happends also my tape is stuck in camcorder
  • 2 more comments
  • markallenb Jan 06, 2008
    I have the same problem too. Any suggestions?
  • Anonymous Feb 20, 2008
    when i turn it on it says error 1 and in safeguard mode and then it says remove and reattach battery when i do that nothing happens and it says the same thing
  • kilrb70 Dec 14, 2008
    Mine is doing the same, and it refuses to open the tape compartment
  • roaima Dec 17, 2008
    Only posting to be notified when there is a solution (if any)
Http://www.fixya.com/support/t103751-in_video_mode_error_code_message_e01 resolved it for me... Apparently the JVC cameras have a little button that detects the presence of the battery, but it doesn't move very freely and you really have to slam the battery onto the camera before it notices. Cleared my E01 fault first time after having been getting more and more frustrated since it first locked up
Chris
Posted on Dec 23, 2008
We had the same problem and the cassette compartment would not open. We took the battery pack off of the camcorder and then it would eject the cassette. Don't know if it makes the safeguard mode go away but we got the tape out. Hope it helps a little.
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
JVC GR-DVM55U Error E06
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
Unit in Safeguard Mode, Error Code 01
Wow! This is the same problem that I am having since I brought mines in 2006. This is imagining that this same problems and happening to many. Maybe it was a lemon of this product.
Dec 24, 2008 | JVC Video Cameras
Unit in safeguard mode
I found the solution on another web site. You just eject the tape, and then give the camera a few sound whacks near the microphone (I tapped mine of a carpetted floor). Believe it or not this seems to work! My camera had been in "safe mode" for over a year without any success in fixing it. I tried the above method having lost all hope of ever using it again, and presto, the think came back to life! Can't say how long it will last, but at least it's out of safe mode;-)
Dec 16, 2008 | JVC GR-D31EK Mini DV Digital Camcorder
Error message 06 appearing, I can't clear this eero, please help.
remove the battery for some 1 day and then try .. if you have connected the dc plug into the jack remove that also ....
Feb 11, 2008 | JVC Cybercam GR-D30 Mini DV Digital...
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
Cant record, cant open the cassette
The error E01 refers to loading motor problem. The camera will have to be taken to a JVC agent for repair.
Sep 19, 2007 | JVC GR-D250 Mini DV Digital Camcorder
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all JVC GR-SXM265 S-VHS-C Analog Camcorder Questions
JVC GR-SXM265 S-VHS-C Analog Camcorder Logo
512 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
