Question about GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH
Freezer not getting cold
I bought a used chest freezer. Its 4 foot long, 3 feet tall and 2 feet wide. I plugged it in over night and checked it in the morning and it still was not cold. There was nothing in it over night, could that be the problem? It is on the coldest setting being setting "7". I can not hear it running, but the light on the front of the freezer is on, so it must be on, how do I check it to see what is wrong with it?
Thank you,
Alissa
  • 4 Answers
Open the area where the compressor is behind the unit. Should be a few screws to access it. With freezer plugged in place your hand on the top of the compressor. Is it hot?? ...yes and you can feel an international click every minute or so??? The compressor is dead and is going off on an internat overload. Or..... the motors starting components are dead not giving the compressor the added kick start it needs to get going. It's called a 3n1 start kit for compressors it's a universal starting component for compressors and comes with directions how to install
Posted on Jun 25, 2017
  • GE Master
  • 3,497 Answers
Alissa,
Try placing two or three jugs of water in the freezer and wait 36 hrs. before opening.. If the water is frozen solid you have no problems.. if its not frozen, the call a service tech..
Posted on Jun 22, 2017
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
  • 5 Answers
SOURCE: Cold morn - not starting. Car was moved a few feet night before.
OK, so starting the engine uses a lot of battery power, and the engine needs to be left running a while to recharge the battery.
When it is cold batterys don't hold as much charge (not quite the correct technical term, but I don't want to go into battery mechanics and chemistry here). You either need to pop it on a trickle charger or let it run for at least 15 minutes.
Posted on Dec 28, 2008
  • 226 Answers
SOURCE: my brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Posted on Apr 29, 2009
SOURCE: the front surface of the chest freezer is
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Posted on Aug 19, 2009
Testimonial: "Thanks for your useful advice."
iwillfixforu
  • 619 Answers
SOURCE: Ice build up in freezer...Auto Defrost not working
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from repairclinic.com
Posted on Jan 31, 2010
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
Jul 20, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
    your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
    Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
    Chest freezer repair
    I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
    Jul 05, 2009 | Freezers
    I have just bought an old kenmore freezer
    could be freon to plugged freon lines probably not worth the cost of a service call and if it's that old it uses r-12 freon very expensive .Tom
    Jun 15, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
    My brand new freezer wont freeze
    Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
    New chest freezer not getting cold
    Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
    GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
    310 people viewed this question
    Top GE Freezers Experts
    Charles T Nevin
    Charles T Nevin
    christian nielsen
    Victor Nwachukwu
    Victor Nwachukwu
    Are you a GE Freezer Expert? Answer questions, earn points and help others
