Question about Symbol LS 4278 Barcode Scanner
3 Beeps after trying to scan
Lately my scanner has been beeping 3 times after trying to pick it up and scan, Usually when its been sitting over-night but also other times too.. it will beep in a 3 beep pattern that the pitch gets higher with each beep. when you sit it back on the cradle for a minute to "charge" it seems fine for a while.. im sure its some sort of electrical issue but not exactly sure.. anyone?
    Scholar:
  • 74 Answers
If you are receiving three quick beeps (all the same tone) before a scan the battery is low. If the scanner is more than two years old the battery may need to be reconditioned. It is recommended the battery be reconditioned once a year. The latest revision of the LS4278 manual is here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=134112767&stateId=0%200%2014115220
Print page 28 of 414 and scan the Battery Recondition barcode. The scanner will discharge the battery then charge it up again. It goes through this two times so you need to leave it on the charger a while for this process to complete. Hopefully this will resolve your issue. If not, you may need a new battery.
If the beeps are low, medium, high the procedure above still may work, but you might want to call Motorola for assistance. Sometimes hearing the beeps helps to diagnose the problem.
Posted on Oct 09, 2009
Testimonial: "you are AWESOME! that was exactly the problem. thanks man!"
  • Symbscanners Sep 11, 2015
    You can put the scanner in the charger and lift the nose just enough to slip the barcode in to scan.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Check battery date if older than 2 years change battery.
Posted on Dec 08, 2015
How do you recondition the battery if the scanner is not emitting the laser?
Posted on Sep 09, 2015
    Hi, I replied but it went to the main answer rather than your comment. Put the scanner in the cradle and lift the nose just enough to put the barcode under the beam. The cradle is supplying power so you should get the beam.
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
Randomly beeps for no reason at all. Can go 2 or 3 days then will start beeping. Day or night usually through the night.
hey i have the same problem. how log does it do it, how many beeps and how quicky. We have a danby also the 1.1 bought it about 3 years ago.
Aug 04, 2010 | Danby DMW753 Microwave Oven
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
My g40 will not boot up when i turn it on it beeps 3 time with equal time between beeps and then shuts off never getting the screen ti light up
The beeps indicate that you have a RAM memory problem. Did you install new RAM lately? If yes then try removing the new RAM module and try again. If not then maybe your existing memory module has gone bad. Try replacing the RAM memory.
Feb 03, 2010 | Computers & Internet
I just got an LS4006i scanner with a ps2 connection. When I plug it in, it beeps 3 times. When I scan a bar code, it beeps once and the lite turns green, a slight pause the 3 beeps. nothing comes up on the...
The cable has to have a PS/2 keyboard connected to it and you must be connected to the keyboard port. Unfortunately this scanner did not support "Notebook" mode where you could make it think it was connected to a laptop and leave the keyboard connection open. The other thing to check is that the "IBM PC/AT" barcode is scanned from Adobe page 55 of 182 of the LS400Xi Product Reference Guide.
Nov 20, 2009 | Symbol LS4006 (SYMLS4006I10014) Handheld
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
Beeps 3 times and power light flashes
I have not solved the problem. I just changed to a different printer. I had a bj50 printer and it use to do this and would change the printhead but they are expense and I have 3 different ones so believe it is something else that is wrong with this one.
Apr 18, 2009 | Canon BJC 85 InkJet Printer
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Symbol LS 4278 Barcode Scanner Logo
7,152 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
