Question about Brother DCP-7020 All-In-One Laser Printer
Back door open alert - Brother DCP-7020 All-In-One Laser Printer
    President:
  • 1,187 Answers
Twist the printer so that you can see the back of the printer.
Near the bottom, there is a door that swings down.
Swing it down and it will open (get familiar with it). Then close it. There is a magnetic catch.
Posted on Oct 05, 2009
Light delay switch not working
I am not sure what you are talking about. Do you mean the intruder alert? Intruder alert: The light bulb on the garage door opener motor comes on when the inferred safety beam in broken for a specified amount of time.
Mar 02, 2015 | Sears Craftsman LiftMaster Chamberlain...
Cooler Compressor runs but cooler won't get cold?
If the compressor kicks in then check the lines to see if they are cold. It is possible the compressor burnt out from leaving the door open. Purchase a sensor alarm to alert you if the door is left open.
Nov 16, 2013 | Coldtech S3BRR-18S Commercial Refrigerator
Air bag light is blinking
This will be a alerting you to a fault, but to reset the computer to stop the light flashing what you need to do is the following:
Turn the ignition on (till all the lights n the dash come on) just as the airbag light goes off, turn the ignition off quickly and press the door closure button quickly 5 times (the one that alerts you that the drivers door is open) then turn the ignition back on. This should work, but you may need to do it a couple of times.
Alternatively, you can get a diagnostic test done through an auto electrician, that will tell you what the fault is, so that you can get it fixed.
Nov 15, 2013 | 2002 Mazda Millenia
Alert/Alarm for key/headlights no longer sounds
The owners manual should help shed some light on this problem. The car may be somewhat programable for the alerts and warning systems. You may also need to lubricate the door button that senses the door is open and closed. Good luck.
Dec 10, 2012 | 2003 Honda Civic
Key Alert Continues to Sound after key removed from Ignition
should be a fuse in the fuse panel for door alarm simply pull the fuse out for the easiest fix
Aug 04, 2012 | 2010 Jeep Liberty
The interior lights of my 1995 ford bronco will not turn off! help! specifically, this is the situation: The interior light overhead is on, and so is the light in the passenger side door, as well as the...
One of two things are going on. You have tapped into the interior lighting circuit while installing the CD player thus shorting the lights to ground. Or you have a dead short in the wiring harness in the door/hatch/ignition circuit that is telling the rely they are open,,hench the bing alert you get.
Feb 26, 2010 | 1995 Ford Bronco
Changed ink cartridge; can't eliminate"door open" alert
Hello sir; On the door hing, it conect with door senser when the door open or close going to actuact the door senser, so check the door senser is moving free.
Aug 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Bell wont stop ringing
Thankyou,
Bonjour, dearest Sir/Madamme, it would be an honor to help you out, the bell is a door open and close alert system in the Elite. They are usually activated with time. On the hinges on the doors, there are sometimes tilt switches, the tell the circuit system when to alert, as soon as the door is open some count time, if the time is prolonged, and the switches are open, (that would mean the door is open as well). They activate. I would check the door hing, a swith could be open/closed depending on the format of operation.
Thankyou, :)
Jun 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Brother DCP-7020 All-In-One Laser Printer Logo
194 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
