Question about Tascam CD-RW2000 Burner
Turns on but won't respond
The display lights up and says Welcome. That's it. Obviously I have a failure somewhere. I opend the machine and found no signs of trouble just by looking around. I got voltage on all the different boards. That's about all I'm qualified to do.
By any chance is there any kind of reset routine when turning the machine on?
Has anyone dealt with this kind of failure?
Thanks, Kerry
  • renodude Dec 30, 2007
    Huh? The machine is a CD-RW2000 professional CD burner, not a personal computer. Thanks for trying.
  • ThomasFY Mar 31, 2008
    Just discovered the same problem with one of our CD-RW2000 units. WELCOME scrolls across the display one letter at a time but the exclamation point at the end never makes it to WELCOME! ...
Having same problem with my tascam cd-rw2000 at first i would just turn off then back on, now that doesnt even work.... i need help!!! and suggestions as to what went wrong?
Posted on Mar 16, 2008
  • 2,427 Answers
IS IT A LAPTOP OR DESKTOP ?
IS THE WELCOME SCREEN THE WINDOWS WELCOME SCREEN OR THE MACHINES BOOT WELCOME SCREEN ?
IF IT IS THE WINDOWS WELCOME SCREEN then format and reinstall windows followed by your drivers and software
IF IT IS A DESKTOP and its the boot welcome screen (MOTHER BOARD MANUFACTURE) the try flashing the bios, look for jp1 its cloe to the battery it should have 3 pins and a jumper. the jumper should be on 1 and 2 leaving 3 free, put the jumper on 2 and 3 for 5 seconds then putting it back on one and 2.
If that dont work remover the rams and flash again
If that dont work disconnect all hard drives and other drives from the board and see if it boots. IT WOULD SAY INSERT SYSTEM DISK
if that happens it means one of your drive is bad connect it one by one until u find which and replace it..
IF THAT DONT WORK CHANGE YOU MOTHER BOARD
IF ITS A LAPTOP
DISCONNECT THE BATTERY , remove the rams and there is anoter smaller batter on the main board, remove it as well
leave it off for a few minuters reassemble and it should work
IF NOT THE REMOVE THE HARD DRIVE AND OTHER DRIVES and see if it boots
if it does replace the drives one by one to see which is bad
IF THAT DONT HELP take it in to a technician for repairs to the main board
Posted on Dec 30, 2007
My hp Compaq min 110 has a screen display problem, one can turn it on but the screen responds nothing....
If all is normal with an external display, consider replacing the internal display/inverter.
Mar 07, 2016 | HP Computers & Internet
Asus oplay 021 not working
If it is a new remote, obviously it's defective; return it and claim your warranty. If can't get it repaired or changed, buy a new one
Remote Control For ASUS Play OPlay oplay021 HDP R3 Live Mini Plus HD HDTV...
Remote Control For ASUS oplay021 OPlay HDP R1 Live Mini Plus HD Box Media...
Remote Control For ASUS Play OPlay oplay021 HDP R1 Live Mini Plus HD HDTV...
Feb 20, 2013 | Computers & Internet
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
Welcome to LG-LG 855 won't respond
MY BOOST MOBILE IS AT THE WELCOME TO LG-LG855 SCREEN IT SAID TOUCH THE ANDROID TO BEGIN WELL IT NOT DOING ANYTHING WHEN I TOUCH IT WHAT DO I DO
Mar 11, 2012 | Cell Phones
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
Pushed start button to begin cycle. washer started beeping and display was flashing F and the DL repeatedly. unplugged washer for a long time, opend and closed door. also checked water pump screen in the...
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Apr 25, 2011 | Washing Machines
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Tascam CD-RW2000 Burner Logo
    346 people viewed this question
    Top Tascam Computers & Internet Experts
    Ben Armstrong
    Chris Larocque
    Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
