Question about Kenmore Dryers
Won't heat - Kenmore Dryers
  • Kenmore Master
  • 7,482 Answers
You did not say if you had an Electric or Gas dryer.
My expertise is with Electric Dryers.
If you have an Electric Dryer then you problem is probably the heating coil or thermostats.
Unplug the dryer.
To check them remove the back of the dryer, locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and thermostats.
Remove the wires from the heating coil. Use a continuity meter on the two terminals to check for continuity...if you do not show continuity, then the heater coil is probably faulty.
Good luck,
I hope this helps
Posted on Oct 05, 2009
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Apr 07, 2013 | Biddeford Blankets Heated Mattress Pad...
Whirlpool WGD6200 won't start
When you say it won't start, do you mean it won't heat up or do you mean it won't spin?
Nov 07, 2012 | Dryers
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Cook top won't work and oven won't heat
check the plug it sounds like the plug is not secure only getting one leg of current push in firmly
Jul 29, 2012 | Maytag MER5775Q Electric Kitchen Range
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Aug 28, 2011 | Whirlpool GEW9250 Electric Dryer
Heating element won't shut down
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Jul 31, 2011 | Kenmore Dryers
We have an Amana Easy Touch Control 500, the pilot is on but oven won't heat up. We also can't self-clean because the door won't lock or sometimes it locks and won't open. I suspect the...
Most likely the door for your kitchen range has a sensor that is not allowing it to heat up because it detects that the door is not closed.
I would suggest you consult help from a certified technician by the manufacturer of your Kitchen range that way they would also be able to check other possible faults on your kitchen range and replacement parts would be 100% compatible.
You can also check the services that these guys offer:
http://www.stoverepairnearyou.com/ml2/?v=1640662349&u=08E0B192DFA88BAA0210818080F80718DDA9032090DEAEEC8F8CA8CFC401
Hope this helps!
Jul 18, 2011 | Amana ACF4225AS Electric Kitchen Range
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
