Question about Guillemot Hercules Deluxe Webcam
Broken wire on my webcami have a replacement usb cable, but i need to know where to solder the wires on the webcam pcb side
Need spares website details as PCB is broken
if the printed circuit board is broken you need to solder new wires across the places where the copper traces have been broken because of the break
Feb 19, 2015 | Office Equipment & Supplies
SoundSticks HUMMING/BUZZZZZING
the cable is broken, you have to replace it or find out where it's broken and shorten it
Dec 05, 2007 | Harman Kardon SoundSticks Computer...
The red and black wires from the pcb mounted on the battery of my Garmin Streetpilot C510 have broken off. Do you know which wire goes where so that I can solder them back on or where I can get a...
The battery terminals are fairly easy to find which goes where. The PCB itself should have a + or - symbol depicting that black solders to (-) and red solders to (+)
May 04, 2011 | Garmin StreetPilot c510 Deluxe GPS...
I have a Akai 32" lct3285ta tv. The video went bad. I had another one with the screen was broken, where I had previously used the power supply. I open it and replaced the power on the one in question. ...
This cable is an interference fit cable, and slots, pushes into a header female clip on the PCB. Cold solder will not work, as you found out. You really need to obtain another cable, and detach it from the other end, and replace it in total.
If that's not possible, then your only other way, would be to obtain some fine wire, a very low power soldering iron, a fibreglass pencil, 7 fine solder. Now you would need to identify, where it connects to, and with very fine wire, run a wire from each, connection on the ribbon cable, and solder it to the corresponding place on the PCB. You use the fiberglass pencil to clean off any coating to expose a solderable surface, on the wires, then quickly attach, the fine wires, then when they are done, use Kapton tape or similar and use that to secure and support, the joins, (Sometimes I use hot glue, and lay it down in a position making sure nothing is touching etc, and apply hot glue in a bead right across the joints and it keeps then in place insulated and isolated. Anyway once you have done that, then you need to solder the other ends of the wire to where they would have gone, on the PCB. again make the connection, and use tape, hot glue whatever, and secure that too. If you are careful & have a good magnifying glass, glasses, and patience it can be done.
As an aside here could you not take the cable off from the other set you have, maybe they are the same? Then you could use that one?
You really need to get what we call a service manual, this has all the parts in exploded diagrams, schematics, circuitry etc They are just invaluable. If you contact Akai, they will provide you with one. I have searched the 'net, but have been unable to find one. In the manual there are parts numbers and descriptions, maybe you would be able to purchase a replacement, if you cannot, make or retro-fit the other one?
Sep 12, 2010 | Akai LCT3285TA 32 in. LCD Television
Broken dc power socket
In the case of your laptop, the dc jack is connected to the motherboard by a cable and socket...so there is no soldering that needs to be done. You just have to disassemble the laptop and replace the cable. Below is the link to Ebay where they have one listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=Toshiba+Satellite+A100+dc+plug&_sacat=See-All-Categories
Below is the link to the service manual for the procedure.
http://tim.id.au/laptops/toshiba/satellite%20a100%20a105%20tecra%20a7.pdf
Jun 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Keep lossing power to windows and door locks on 1979 camaro
Check the wires that are inside the boot that runs between the drivers side door and the body of the car, there might be broken wires inside the boot, and any broken wires that you do find should be soldered well and use heat shrink tubing if you want the connection to last.
May 18, 2010 | Cars & Trucks
Tomtom one xl usb socket broken off main pcb
I have gone around this problem by removing the internal battery, and soldering a female power connector to it.I now it on 3 aa batteries, alkaline cells givbe me an autonomy of about an hour, maybe duracells will give a bit more duration.
When i have time ,I will work on splicing the wires on the cigar plug adaptor and use that as a permanent power source. The wires for the Lipo cell are Red positive, solder this to the yellow wire( probably a battery gauge wire) and black ground.
Hope this helps
Very poor workmanship from TOMTOM
Nov 13, 2008 | Tomtom One XL GPS Receiver
Leapster broken black wire.
Black is usually negative Or nuetral, so your assumption would be correct.
As for the cicuit Board end or PCB Side, i,d look to see where the Red from the battery goes on to the Motherboard. Observe the Size of the Solder Spot, and the Black Should be in Close Proximity to that. To be more sure, if you desolder, the spot.
And put a magnet on the desoldered/Solder. any remnants of metal strands, from the broken Wire, will magnetise.
As solder is mainly non-conductive. Tin/Lead.
If there are no visible signs, of the Black-Wire being adjacent to the Red. Look On The Opposing side of the Board.
The Additional Hint Here, Is to gauge by the length of the Wire.
Hope This Is A Fixya For You.
Mike @ Compurepair.
Feb 25, 2008 | LeapFrog Leapster Electronic Book:...
The USB connector broke!
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
Jan 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Broken flat ribbon cable on SD 28 flash
Hello, after breaking mine this morning I was able to fix the flash so It can fire from the hotshoe.
Any automatic TTL features will still not work however atleast you will be able too fire in auto, and manual modes.
I simply opened the flash by taking off the hotshoe, and then swiveling the flash head 90 degrees to expose the four screws there. You need only remove the two screws from the front side of the unit.
Open the battery door and gently pull away the front case (Be careful there are several delicate ribbon cables that you do not want to snap. From here you can either unscrew all the ribon cables to free yourself room to solder or try and dodge them.
You should now be able to see the rear side of the PC sync socket. There is a blue wire that joins the outer edge of the socket - this is ground. Solder onto this point and join onto the top left circle of the PCB board of the hotshoe. (Opposite corner from where the ribbon cable attatches) There are copper circles exposed on the pcb for easy soldering.
Next, return to the rear of the PC sync socket and note the orange wire coming from the centre pin. Solder a wire to this point, and then down to the hotshoe PCB and to the circle that joins to the centre pin of the hotshoe. (Trace the circuit paths)
Sorry I did this about 30mins ago and I'm remembering this out of my head.
Goodluck
Jan 07, 2008 | Nikon SB-28DX TTL Flash
Guillemot Hercules Deluxe Webcam Logo
95 people viewed this question
Top Guillemot Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
ray gallant
Are you a Guillemot Computer and Internet Expert? Answer questions, earn points and help others
