Question about HP DeskJet F4280 All In One Printer InkJet
My F 4280 HP printer is printing partial lines, blurry lines but the ink shows it has ink? How do I fix this?
SOURCE: occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
Posted on Nov 24, 2008
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
  • 159 Answers
SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Posted on Mar 15, 2010
dj_relly999
  • 4070 Answers
SOURCE: I just changed the ink cartridges in my HP F4280
Hi! You may want to try head cleaning to resolve the blurry prints. The smudge may be caused by a full waste ink pad. Try to replace the wastepad and it may resolve the problem. Hope this helps and have a good one!
Posted on Jun 05, 2010
Testimonial: "That's all it took! Thanks!"
My hp 4280 all in one printer says i am out of ink both cart are new.
Good day.
Choose Tools>Print Test Page and check if you still get the same message out of ink. Also check the ink level report on the page which is very important.
If it says out of ink or ink level report shows no ink, check the new ink cartridge and take off the plastic cap off the nozzle.
Reseat the ink cartridges, restart your printer. (Power it off then back off) Check if it's the same issue. If it is,it would also be best to Align the Print head. Setup Menu>Tools>Align Printhead.
Jun 28, 2011 | HP Photosmart C4580 All-in-One InkJet...
I just changed my ink cartridge on my F4280 hp printer, now my printing is blurry
Hello.
Try running the print head alignment feature through the computer. (Click Start - Control Panel - Printers and Faxes - RIGHT CLICK HPF4280 - select printing preferences - select maintenance - select cartridge alignment and follow the on screen instructions) This can also be caused by solid pieces of ink stuck inside the print head disrupting the flow. if it a genuine HP cartridge contact HP for a replacement. The link below shows how to clear blockages also http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
May 28, 2011 | HP DeskJet F4280 All In One Printer InkJet
How do I find ink levels in HP Deskjet F-4280 printer. /Maggi
On your PC:
Start
Control Panel
Printers
Right click on this printer
Choose printing preferences
Open Services Tab
Jan 10, 2011 | HP DeskJet F4280 All In One Printer InkJet
The ink cartridge was replaced, but it won't print all of the typed words and those is does print are not clear. How do I replace the cartridge correctly?
It is the print-head that sprays the ink onto the paper that is partially clogged. So, you get "white-lines" across some lines on a page. Run the HP Printer Assistant, and do a "head-cleaning" cycle.
Sep 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
Replaced both inks in hpf 4280 but printer is still showing empty and wouldnt print calibration page how do i manuall resent ink levels
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Sep 09, 2010 | HP DeskJet F4280 All In One Printer InkJet
I just changed the ink cartridges in my HP F4280 printer, and now documents are printing blurry, with horizontal alternating dark and light lines, as well as some smudging along the left margin. What can I...
Jun 05, 2010 | HP DeskJet F4280 All In One Printer InkJet
My hp 4280 all in one wont print. it shows an
Rather than to analyze your problem and fixing, just uninstall all the softwares related to your printer from the control panel and reinstall them back using the driver cd came along with your printer and this should fix your problem. If still the problem persists, then try connecting and printing from any other PC/laptop to find out where exactly the problem is.
I hope this is helpful to you.
Thanks
Feb 07, 2010 | HP DeskJet F4280 All In One Printer InkJet
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HO 4280 does not print
if your ink light is on, you have no more ink and need to get it replaced.
Dec 12, 2008 | HP PhotoSmart C4280 Laser Printer
HP DeskJet F4280 All In One Printer InkJet Logo
74 people viewed this question
Seeker5211
Seeker5211
