Question about Harman Kardon CDR2 2-Disc CD Recorder
What kind of cd's are necessary to record with the CDR cd harman kardon recorder, I put the blank digital vinyl CD-R disk and the CDR gives me a NON-AUDIO answer and I can not record
  • 41 Answers
You need CDR Music. CDR Data will not work in a consumer CD recorder. Professional CD recorders do not have this media limitation.
Posted on Oct 06, 2009
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
I have a Harman Kardon cdr 30 that I use to burn my analog Vinyl and cassettes to cd. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
try plugging the HK30 out to R2R in, R2R out to RECV in...RECV (you may need 2 rca "Y" connectors) tape out back HK30 & Cass
the "Y" connector needed is (2) 2 female to 1 male (connect both HK30 & Cass deck)
May 15, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
I have a Harman Kardon CDR 30 that I use to burn my analog Vinyl and cassettes to CD. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
do you remember how your connection was before the RR tape deck? if so connect it back that same exact (when every thing was recording / playing) way as before....(you also need to purchase 4 gold tip "y" connector jacks (2 RCA female to 1 RCA male)) ... in / out jacks you just plug the cassette deck will be shared with the RR tape deck...just note you will not be able to record from cassette to RR tape or vice versa...but you will be record from all other sources...
feel free to rate the help
Mar 27, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Recording audio only from an HDTV concert
Have a look at the manual for your AV receiver, you may find that you can change the digital output format between DTS mode and PCM(audio) mode. It needs to be in PCM(audio) mode for your CD recorder to be able to record digitally. If that doesn't solve it I can only suggest recording in analogue mode, i.e. taking a stereo analogue signal from your receiver to the analogue inputs of your CD recorder.
Hope this helps
HifiJohn
Jan 04, 2009 | Harman Kardon CDR30 2-Disc CD Recorder
Blank cds don't work
Are you using cds labeled music? These are formatted for cd audio home recorders. Data cds for computers will not work. If in doubt, usually on the packaging it states for home audio.
Oct 27, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Mar 08, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Harman kardon CDR 26 cd recorder
It's the belt from the spindle motor to the gear. It's worn and can't grip the spindle anymore. If you elp it to start off it works. Open the unit, remove the cd tray and it's underneath at the front. You can replace with a similar size elastic band.
Nov 14, 2007 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon CDR2 2-Disc CD Recorder Logo
200 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
