Question about InFocus Office Equipment & Supplies
Signal out of range I keeop getting the above
Signal out of range I keeop getting the above message. What does this mean and what must I do?
  • 2,237 Answers
The resolution does not match from the computer to the projector. reset the settings on the projector to factory default. if that does nothing, drop the resolution on your computer. if you are doing hd video, check to see if your projector can handle that. if it's more than 3 years old, chances are it cannot.
Posted on Oct 21, 2009
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
Www helpouts google com
Try resetting your graphic to default and reset the monitor to factory default.
May 04, 2014 | Televison & Video
Code 21,43,and 42
You have two oxygen sensors but 21 is upstream sensor. This is the sensor between engine and catalytic converter. There is three possible problems that it could be.
1 oxygen sensor input voltage maintained above the normal operating range.
2 no signal at 02 2/1 sensor
3 oxygen sensor input voltage sustained above thenormal operating range. What all this means is you need to replace the sensor.
when getting the replacement this is your O2 2/1 sensor.
May 13, 2013 | 1996 Jeep Cherokee Country
Input error
If you are getting the no input or out of range message on your screen then you will need to do one of the following:
No input
If you aren't getting signal then it means that your graphics card has failed. Make sure the video connectors are secure. If all connectors are in place and you still don't get a signal then you will need to:
Connect the video cable to onboard graphics if you were using a graphics card. If you're not using a graphics card then it means that your motherboard vgraphics has become faulty. You will need to consult a repair technition.
Out of range message
If you are getting this message then you will ned to change the refresh rate on your monitor. To do this boot your computer into safe mode by pressing F5 during boot up. Then right click on your desktop and click on properties. Then click on the Settings tab and click Advanced. Once in the Advanced settings click on the Monitor tab. Then all you will need to do is set the refresh rate down to a lower setting like 60 Hertz.
Feb 19, 2011 | Acer X183H 18" Monitor
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
I just reloaded maps on my Tomtom but I am getting the message'' Waiting fora valid Gps signal regards charlie
That just means that your not in good range of the satellite that the TomTom uses. Think of it like cell phone reception. Try waiting a few minutes or going to a different area. I have the same problem because I live in a forested area, but when I leave and go into town, I'll get a signal.
Jan 13, 2010 | Tomtom ONE XL GPS
An Out of range box
frankr2327
If you are getting this message this means that you are connecting a device to the monitor and/or a connection that is putting out a signal that is not supported but the monitor. You may also need to look at the cable you are using. Example I have an XBOX 360 with the official VGA cable when I use it to connect to my monitor it works fine. However I have been testing cables to get a setup for my PS3 as I have not been able find an Official one from Sony. So when I connect my RBG to VGA cable to the end of my RGB XBOX cable then to my monitor I get an Out of Range message. So something with the cable is case a problem with the signal to not to be sent properly.
Note with monitors they have a safety feature that they would turn off if they got a signal they did not properly support and/or not read properly. This has always been there they just not got where they would show you a message. Plus with monitors getting bigger they have stopped supporting lower resolutions so you may see this issue more often when hooking up older devices. I my self still have a 15 and 17 inch on my work bench for toubleshooting.
Hope this helps clarify things. Feel free to reply back with what device you are having trouble with.
Issken
Dec 30, 2009 | Envision Computers & Internet
"Out of Range" - Message
it means that the signal it is being fed with is not within its resolution range. Does it work OK when attached to the computer? What kind of video resolution the AV transmitter out out?
Nov 03, 2009 | LG 15LW1R 15 in. LCD Television
Hi I get a "signal out of range" message until windows xp starts. This means I can't get into safe mode or see start up messages. Any ideas please?
You see "Signal Out of Range" does not mean you cannot go to Safe mode or see startup messages. It shows up when you dont have a display. The refresh rate of your monitor is a little slow. So when you wana go to safe mode, press the Power button and start pressing F8 option and you will get the safe mode option and you will see startup messages when you will get one. Your computer is perfect. :)
All the best.
Regards,
Shrey
Oct 09, 2009 | HP L1955 19" LCD Monitor
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
495 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
