Question about Dell Dimension 2350 PC Desktop
2350 dead, not starting, just green flashing on board, no fans
Switch works and chec ks out, now what
    Problem Solver:
  • 6 Answers
Pull your hard drive and install it as a slave on another machine. If you can't read from it there, your hard drive is toast.
Posted on Oct 06, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
OregoniaDuke, gave you the best answer possible. The green flash at post is a dead giveaway to this problem. I have seen this before in the past. If the hard drive checks out OK, then check your Video Card it too will cause the green flash.
Posted on Oct 18, 2009
Our 2350 will power up, bootup and then turns itself off. tried new power cord with same outcome. Any ideas?
Posted on Mar 28, 2011
  • 3 Answers
well figures, computer store guy said not worth fix, PS and mob are bad , so then heard of another option, Freshmen in high school,13yro put in a used power supply and memory card. All seems well again.
What would be the cause of my Paslode fan not working batteries are good
First, check to make sure you have a flashing green light in the handle - if not start with the battery contacts / circuit board (Part #22 on the exploded diagram)
If you have a green light, I would look at the head switch -
1) remove the 4 bolts from the head
2) remove the 2 screws in the nose holding the cylinder to the handle assy
3) carefully remove cylinder by pulling nose out and down taking care not to bend your fan blades
4) On the handle assy you will find a metal tab with a small roller on it (Part #27 on the exploded diagram) - this is the actuator for the head switch, make sure it is not bent and that it actually works the switch inside.
5) If the actuator is OK, I would lean toward the head switch which is part of the circuit assy (part #22 on the exploded diagram) (It is possible you have a bad fan motor, but it is much more likely you would have a bad switch)
Let me know if you need further help
Jun 22, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
No power to motherboard Shuttle AN35n ultra
Hi there
Try One of the following steps:
  1. Flash Youre MB BIOS.
  2. make sure that CPU Fan is working OK.
  3. Is the CPU attached to the MB correctlly.
  4. Is the CPU Fan base and scrowse faremly scrowd and positioned on the MB.
  5. Chec MB in/pot power pins connections.
Hope That will Help.
May 16, 2009 | Shuttle AN35N Motherboard
Windows XP won't start
The amber light is the error light on a Dell. It can mean a few things. 1. RAM has went bad, not properly seated. 2. Video card has went bad or come unseated. 3. Power supply is not working properly; or 4. Motherboard has went bad. Hope this helps & please remember to rate my answer.
Jan 02, 2009 | Dell Dimension 2350 PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 2350 PC Desktop Logo
203 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
