Question about Garden
I own a YS 4500 Craftsman tractor (Model No. 917 287 242). It was running fine the last time I used it but then wouldn't start. No response when turning key. I checked battery with multimeter - it's fine. I think the under-the-seat circuit breaker switch has malfunctioned. What do you think?
  • 389 Answers
If you think it is the seat switch you can check it with your multimeter, just unplug it and check the resistance across the switch with and without pressure on the seat where the switch is located. Another way to test would be to take a short jumper wire, unplug the switch and jump across the 2 wires in the plug, then try to start it.
I would be more inclined to think it is the fuse in your system, however. Most of the time the fuse is a plug in fuse located on the right side of the tractor, behind the back of the engine and is usually a blue (15 amp) or yellow (20 Amp)
Posted on Oct 05, 2009
  • vincevanscoy Jul 30, 2011
    I had the same symptom, . I checked the fuse and it was blown. I put in a new fuse and sprayed some carb cleaner in the carb. I turned the key and the mower started up. After a minute of sputtering the idle smoothed out and it is running great.
My craftsman ys 4500 just stopped pulling the engine starts and runs fine it just wont move
Check the main drive belt, and the linkages from the brake clutch pedal to the pulley that tensions the belt. If you do not find anything there, then remove the back panel, jack up the mower, and turn the transaxle pulley by hand to see if the wheels turn, make sure it is gear.
If you are lucky, it will be a slipped belt or broken belt. I hope this helps get you going.
Aug 19, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
try pulling the hose off from the carb and hang it into a pan so that gravity will help it drain into the pan...good luck
Mar 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Sep 07, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
