Question about Samsung HL-P5063W 50" Rear Projection HDTV
Screen went B&W and I hear a loud humming noise from the TV...
Just heard a "Pop" and the picture went black & white, then a humming sound started. Is this both a color wheel and bulb problem on a Samsung HLP5063W 50" DLP? John
  • Antonio Cruz May 11, 2010
    Hi,if lamp was bad picture will be off.It sounds like you only need to replace the color wheel.This will be the part # you need: BP96-00674A there's 2 version silver or gold you'll have to check which is the one your tv caries.Here's instructions to take out color wheel :http://guides.fixyourdlp.com/samsung/bp9... Good luck and God bless you!
    Scholar:
  • 39 Answers
Hi John,
If you are hearing this noises,that's your Color Wheel.
The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978
I hope this will help,please keep us posted
Posted on Oct 05, 2009
I have a 50" Samsung DLP about 6 years old. Like seagoat, My set is making a "buzzing/humming" sound. Just before it did that I heard a single "pop" sound. For the past week or so the picture has been...
Tv have a colors wheel,hearing a humming or buzzing noises or black&white picture flashes with the picture,the colors wheel is dead.Hire a tv tech. to replaced the colors wheel,it pretty hard to replaced the colors wheel,because have to have take out alots of machanical parts,before even can come to the colors wheel itself to replace it.
Oct 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
I have a HLR5067-W. I heard a single pop from the
Does it still making noise now?Than yes ur color wheel is broken need it replaced.
Nov 23, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Have picture, but no color and loud humming sound
the color wheel needs replacement. You can get a replacement color wheel at www.tvrepairworld.com
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Same humming , but then goes off.
Color Wheel it is you can get one for around 95.00 up depend s on Part# BP96-00674A cost 113.69 Call Encompass Electronics 1-800-638-3328.Just looked it up they have it.
Sep 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Jul 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Nov 29, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
444 people viewed this question
Jerry Greenberg
Jerry Greenberg
